08-31-2009, 05:28 PM | #1 |
Rock Crawler Join Date: May 2006 Location: Georgia
| Axial AX10 Scorpion **On Sale! $50 off**
Axial AX10 Scorpion #AX90001 The AX10 Scorpion is ON SALE $169.99 for a limited time. http://www.tcscrawlers.com/On-Sale-5...1-p-16395.html Features Complete competition ready kit All new axles that feature an improved driveshaft angle and castor as well as class leading steering throw Aluminum Chassis plates with a molded nylon skid plate Ultra compact and lightweight transmission Full time locked four wheel drive (kit comes with diff lockers stock) Full Ball bearings Overall gear ratio range from 15:1 to 74:1 Transmission: 2.6:1; center mounted Differentials: Locked style (spool) Transmission: Single-speed Tires: Axial 2.2 Rock Lizards Wheels: Axial 2.2 Rockster Beadlocks Suspension: 3 Link Drive Shafts: Universal front and rear Chassis Wheelbase: 304mm~320mm (12”~12.6”) Width: 254mm (10”) Height: 156mm (6.125”) Weight: 1588g (3.5 lbs) Articulation: 70° Ground Clearance: 79mm (3.125”) Body Length: 438mm (17.25”) Width: 181mm (7.125”) Height: 133mm (5.25”) Electronics (Not Included) Radio: 2 Channel Servos: 1 (Standard Size) Speed Control Motor: 540/550 Size Battery: 7.2v Stick Pack Axial has designed a completely new kit from the ground up. Each detail has been well thought out and provides you with a solid base to work with. Axles The axles have been designed with many features that are not available from other choices on the market. Everything from the axle strength, pinion angle, caster, and ground clearance were taken into consideration, the result is a stronger better axle that will last. An aluminum diff locker is included along with hardened drive shafts and axles. Chassis The AX10 Scorpion chassis is lightweight and stiff. Twin 2.0mm aluminum side plates are tied together with aluminum posts and a molded nylon skid plate/transmission plate. The chassis was made as small and compact as possible to cut weight as much as possible. A simple battery/radio tray makes installation of your electronics quick and easy. Wheel base is adjustable from 304mm ~ 320mm. Transmission The AX10 Scorpion transmission was designed to place the weight of the motor as low as possible while still allowing a wide range of gearing choices. The overall ratio can be adjusted from 15:1 all the way up to 74:1 using different pinion/spur gear choices. The transmission is locked with no differential action and features hard anodized aluminum out-drive shafts. Shocks, Links and Driveshaft Super long shocks offer a wider range of articulation as well as an optional range of spring choices so you can tune your crawler to work on any terrain. All suspension links are made from lightweight and strong aluminum. The driveshaft is made from super strong composite material and features hardened metal yokes. Wheels, Tires and Body No crawler would be complete without the essentials. The AX10 Scorpion will be outfitted with the popular 2.2 Rockster beadlocks sporting green rock rings and Rock Lizard tires. Also included is the popular B-17 Betty body in .040” thick polycarbonate. |
09-18-2009, 01:39 PM | #2 |
when does the sale end?
09-19-2009, 05:57 PM | #3 |
10-27-2009, 09:26 AM | #4 |
ordered! thanks!
