07-02-2009, 10:29 AM | #1 |
Newbie Join Date: Jun 2009 Location: sacto
| body cutting
i just assembled my venom and am ready to cut\paint the body. tried scissors but the angles are getting in the way and i think it will look kinda choppy. what is the prevelant method?
07-02-2009, 11:14 AM | #2 |
Quarry Creeper Join Date: Nov 2008 Location: St George
To do it right you need a pair of curved lexan scissors, Aside from thaat if you can hold steady an x-acto knife works well to score the lexan and then you can break it at the score you made. Good luck!
07-02-2009, 11:22 AM | #3 |
thanks!!
07-02-2009, 11:26 AM | #4 |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
On the last body I did I cut close to the lines but left a little extra and then I used a small round sanding drum on my Dremel to smooth out the edges.
07-02-2009, 12:47 PM | #5 |
Rock Crawler Join Date: Feb 2008 Location: UK
Curved body scissors to cut almost to the line, then an Xacto knife with a new number 11 blade to pare thin slivers of lexan away until you reach the line. Finish off with 320 grit then 1000 grit wet-or-dry paper. I always remove the protective film around the edges after the initial scissor cut. I find it gets in the way. |
07-02-2009, 12:51 PM | #6 |
Newbie Join Date: Jun 2009 Location: Sandy Eggo
I have a pair of small, curved scissors I got from longs/cvs for like nose hair and stuff lol. Same thing as "lexan scissors"....might save you a couple bucks.
07-02-2009, 02:28 PM | #7 |
Holy cow! You guys are serious about cutting and sanding and polishing and buffing! I just cut with scissors and IF it needs a little sanding fine but even on my 100 dollar painted bodys I dont get that extreme.
07-07-2009, 09:42 PM | #8 |
i use the score and tear method on thinner lexan and then cut the thicker stuff and clean it all up with the dremel
09-20-2013, 11:23 PM | #9 |
Newbie Join Date: Mar 2011 Location: tracy city
| Re: body cutting
sissors, paint then Rock pile. LOL
