Venom Durability Hey I was looking at getting the creeper when it first came out but did not get it because of parts breakage. I just want to know if these parts have been fixed like the axles which I know where breaking. Well thanks for your time. |
all is fixed, the drive shafts are shit outta the box no matter what, best upgrade wile building. |
go to the pro creeper thread drive shaft are ok need to replace the c hub Im running one and have only had one problem and that was the c braeking but the pin backout and broke the c |
yeah give the factory drive shafts the shaft and get after market ones the original drive shafts cant take any torque |
A bit of newbie reality here. The hardware and indeed the whole kit is fine. Not excellent but fine. The durability is great and I am happy so far. This is a RC land vehicle that is made to take a certain amount of stress and impact and for me has lived up to those design parameters so far. Deffo heatshrink the cvd's during the build. The tires can do with a bit of cutting or replacing but other than that go for it. I did "thumbsup" |
I have had my first creeper for a while now and was originally going to buy something different, Axial, or Losi but after the way my creeper held up and how easily it upgraded, I bought another one instead. Almost nothing left of my body from rock damage, but I have only broken one c due to pin coming loose in my CVD, now my CVDs are welded and I havent broken anything since. For the money you simply cant beat the Venom |
I have HAMMERED on my creeper and it keeps asking for more. The only thing I am starting to deal with is the nylon carrier deteriorating where the 3 pins for the locking collar engage. I did not like the way the instructions had you placing one set screw on the yolks for the driveshafts and axles, so I bought a crapload of new set screws from mcmastercarr, and I have two set screws in every joint torqued down as far as I can get it to go before I think i'm gonna strip stuff, with threadlock to keep them from backing out. Its really a good truck, I haven't had any of the common breakage people talk about and Ive seriously been trying to get some. |
No issues except one bearing let go on the c-hub. |
hey im in boise and use a creeper if you want to check it out just email me at vurtrider@cableone.net. i love it by the way! |
Strength wise they are great, the only issues the damn pins coming out, even with lock-tite, shrink wrap everything as you build it. as for the cvd breaking thats because when the pin backs out it hits the cvd and if you just hit the gas somethings going to give right? |
Durability..... I vote for NO. Dont get me wrong here performance wise this VC are same like any other rig on the market but the Quality and toughness of this product are very poor... and i mean really really poor. |
I abuse mine and it's bullet proof so far. My favorite thing is running it across the grass and my dogs will chase it. When they get close I throw it in full reverse and the pups will put the brakes on and run away as I chase them in reverse. That's running 3S and Tekin 55t motor on stock drivetrain (except for Traxxas drive shafts). Haven't had a single thing break yet. |
I just ordered one today from RPP. Knowing what line to take on a course is very important because each rig will have their own strengths and weaknesses. Ask a Pro level driver, they will tell you to learn your rig and know what your rig can do and cannot do. Quality should be on par with other brand and aftermarket parts will strengthen your rig even more. Don't fix what's not broken and upgrade to a better part when the original breaks. "thumbsup" |
Yes my AX,CR01 and other few take the same course/route without any problem only this rig give me this problem. Oh ya if you read most of the post here also asking about parts too.. |
Bullshit Quote:
Pin fix Quote:
The only things that I have broken on my Creeper were due to driver (me) error... yes the driveshafts suck ( replaced with Traxxas shafts and yokes ), the pins in the CVD's fall out ( shrink tube them ), I broke a lower link joint when the rear wheel got in a bind then the rig rolled and came tumbling down a ledge ( easy fix )..... The lockers I have never JB weld them or replaced what came out of the box ( the only thing I did was back the screw out on the axle that is next to the sliding switch, back it out just enough so that the head of it prevents the switch from sliding ) It's durable "thumbsup" Don't let the bashers influence you..... |
Let me preface this by saying, I bash my stuff hard. The Creeper needs only a couple of cheap mods during the build that make it awesome. Just do what the guys here say and you'll have a bulletproof Creeper(that's what I did). It's best to do a couple of upgrades during the build. Here is what I did (based on others experience with the Creeper's weak points) and mine has yet to break. I added FLM lockers, 3racing CR-01 driveshafts and heat shrink the cvd pins. After that it's almost bulletproof and you can spend your time setting up the suspension to your liking rather than fixing broken parts. I let my 10 year old nephew drive mine. It holds up to him and trust me he doesn't understand what don't force it in a bind means. Hope this helps |
It probably has more to do with your motor/power combo. I'm rockin a 45t brushed motor with 7.4v NiMH. I just have the 3racing d-shafts and heat shrinked cvd's and I can stall the motor without breakage. |
It has nothing to do with the motor.The creeper will handle brushless motors and 11.1 lipo with no problem.Some people just like to wank on about stuff just to hear themselves wank.There was a guy on here the other day that said he broke 3 driveshafts just driving on flat ground ,Bullshit!!!!!! The problem isnt these kits its probably improper setup or put together wrong.I dumped mine off of a huge boulder pile the other day and it hit tons of rock on the way down,it hit hard enough to shatter the metal gears in my servo but broke not a single part on my Creeper.Tougher than a two dollar steak bro |
