venom creeper comp build hey guys im new to the forum and am just starting in crawling. ive been in the hobby itself for about 5 years now. so first off take into consideration im only 16 so i dont have a massive amount of money to spend which is why i plan on basically building this over the course of a couple years. so next, i have a venom creeper bone stock im making a list here of items i think ill be using and please tell me what you think and what could be better rc4wd punisher shafts vanquish revolver dh rims weights for rims proline chisel or hb rovers (running on mild sharp rocks) havnt decided on the offset for rims new shocks havnt decided dig unit the list will probly get changed as i go but please whatever tips or thoughs you have on this setup would be appreciated. thanks for the help guys |
You don't mention electronics. I'd say the focus should be on an them, rather than replacing things you already have with the kit. Other than tires, I'd say you can skip the rest and have a fairly competitive crawler. |
Very true, as well as the other things, replace as you have the funds. For a younger guy on a budget, I think getting it rolling should be the priority though. He didn't mention though, so maybe electronics are already covered. |
get traxxas shafts there cheaper and easy to get the stock shocks are good with some tunning and im running the 4VP chassis witch i love some much tunning Hot Racing lock outs knucles and caster blocks and a hand made bta mine runns good just need more time iv only had it for 4 months |
You dont need Punisher shafts,,,way too heavy and overkill for the Creeper. Traxxas steel yokes and Traxxas long truck half shafts wil do the job just fine. Vanquish wheels are nice,,but if you are on a budget there are plenty of Aluminum wheels out there for a lot less. Try CKRCcrawlers.com for some Link series wheels. Get some self adhesive wheel weights form the local tire store. They come in 3oz sticks. Because of the way Creeper knuckles and axles are made you need the wheels with an AXIAL offset. White Dot Rovers are the way to go for just about any surfaces. I also recommend a set of good foams for them too...stockers arent that good and you need the tires planted and filled out but soft in order to make them conform to the rocks. The stock shocks are good shocks if you take your time and build them well the first time around. DIG IS A CRUTCH. Learn to drive the rig based on what its capable of doing out of the box. I compete without dig and run in the Sportsman series here in Colorado. On Saturday we had a local comp and the Sportsman drivers were showing the 2.2 Pro's where the best lines were. Last couple of things from me is this....you now have this thread, stick with it,,if you have questions post them here, if you have made progress on your rig, post it here. One thread per person is much easier to follow. And,,if you havent already,,,,READ. Especially the RMDW Tips & Tricks thread STICKY at the top of the Creeper forum index. There are several people in here who have good working well built machines and they have documented everything you need to know. Let us know if you need help,,thats what we are here for. Thomas @ RMDesignworks & the Creeper Crew |
Have to agree with Thomas on the Traxxas drive shafts and steel yokes. I was looknig at the Punisher shafts as well til someone pointed me towards the Traxxas ones. Bought a pair and have never looked back. For a nice set of Al. rims take a look at the Newage wheels. Running a set on my Creeper and love them. |
DIG IS A CRUTCH. Learn to drive the rig based on what its capable of doing out of the box. I compete without dig and run in the Sportsman series here in Colorado. On Saturday we had a local comp and the Sportsman drivers were showing the 2.2 Pro's where the best lines were. yes it is better to run with out dig in the beginning but you know Thomas you have 53 degrees of steering not all of us have that im at 44 |
Using the dig all the time just takes away from setting the next line you need to crawl. Crawling without dig forces you to think further ahead on course. Use less mechanics,,more thought. |
*update* traxxas shafts i have a brushed setup as of now but its not novak or anything its just a 50t venom motor just to get it rolling servo:definatly moving up to something i still need a idea for that. umm lets see vanquish rims on the mind not first priority wheels leaning to rovers after asking some freinds weights: 3oz weight packs sounds cheaper and more effective than 274 for 8 2 or 3 oz weights. another thing i forgot to mention is battery i was thinking saddles on front axle or a small 1000-1500 mah 2s lipo still gonna either buy new shocks or replace cause i probly didnt build them perfect to begin with can i get a idea for a future crawler system thats fairly nice i know tekin or novak but thats almost a 400$ system so yea im running a dx3s 2.4 so im good with reciever thanks again guys and let me know if you got anymore ideas' ohh how much are the hr straight axle alum parts and were cna i get more stuff like that for my crawler thank guys |
HR Rear Lock outs HR C-Hub HR Knuckles Might want to take a look at say a CC Sidewinder with an Integy Lathe motor or an Integy V10. Also look at a CC BEC. For the Rovers use a pair of Double Deuce Nova Foam |
servo i would go with a hitec hs-7954sh it has plenty of touque and its only $100 and you wont need to replace it for rims i would get proline titus because there cheap and you can get them with 8ox in them right out of the box future system i would get a rooster system great and a 3s lipo cutoff so you can run 3s if you run lipo shocks go with integy of traxxas or losi for shocks what wicked said for upgraids |
I know i'm shamless... but might I sugest checking out my 4VP chassis if you prefer the bodiless look. It's quite amazing and the next version will be out in the next month. |
i want the new one already i dont want to be left behind i have the same chassis i really like it looks cool too and you dont get hung up on body mounts but sorry abam the vulture is worth lookin at too but im with adam on this one the 4VP V3 |
Jeff the Berg rings and AX rings should be the same,,mine are interchangable. |
yea ive been seing everyone with the sidewinder esc on there rig. and guess what my hpi blitz which is a peice of junk had a cc sidewinder 5700. yea but im starting to get a small amount of money so i think first will be the rovers. sooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooo isk what to talk about so im off :shock::lmao:adios amigos |
ohh!!!!! 1 more thing how do i post pictures cause i would realy like for you guys to see my rig right now so please help! |
You can either use your own website if you have one or a place like ImageShack. Then when posting use the [img] tags |
