11-09-2011, 05:40 AM | #1 |
Quarry Creeper Join Date: Jul 2009 Location: israel
| novak goat 18.5 on creeper
a friend of my dad is going to the u.s. and we want to buy brushless for my creeper so i want to know if the goat 18.5 will be good for the creeper or that it will be too big, strong or what ever. roy |
11-09-2011, 07:41 AM | #2 |
Pebble Pounder Join Date: Jun 2011 Location: Port Charlotte
No, unless you want a lot of broken parts.
11-09-2011, 08:44 AM | #3 |
so what you say? to buy faster motor or to stay with my 55T rooster? i want more speed and power together and what pats will it brake? |
11-09-2011, 12:16 PM | #4 |
RCC Addict Join Date: Apr 2010 Location: Ringwood
can you give ua a better idea of what your running like esc motor servo battery and if your running a bec or not |
11-09-2011, 12:35 PM | #5 |
now i'm running stock creeper with novak rooster with the novak 55t, sevo is hs-5955, duratrax 7.2v 5000mah and maybe i will buy li-po. i have no bec |
11-09-2011, 01:04 PM | #6 |
RCC Addict Join Date: Sep 2010 Location: Malta, NY
| the NOVAK ROOSTER CRAWLER AND 55T MOTOR is fine just put a 19tooth pinion. id sugest going to some sort of a HS 7955 or higher servo with a CASTLE CREATIONS B.E.C. unit. id suguest getting a 3cell lipo, it will very much increase the power. id sugest maybe going with a 1000mah 40c 3cell lipo with a nice biult in balancer charger and and u would need a NOVAK 3CELL LIPO SMART STOP, so u dont burn up the esc and your battery.
11-09-2011, 01:05 PM | #7 |
I'm running a novak rooster esc, novak 45t motor, 19 tooth pinion and a 2s lipo. I have alright speed and great crawling power. I'd say for you to keep your rooster, go to a 3s lipo battery & bec and a 35 t motor.
11-09-2011, 01:16 PM | #8 |
| u dont need a 35t motor a 45t motor is more than enought with a 19t pinion. im running a 30t holmes hobbies motor on a 3cell lipo with a axial trans and im bracking alot of things.
11-09-2011, 02:05 PM | #9 |
how to put a 3s on the rooster? it say that it soppurt only 2s 19T pinion with novak 45T motor? edit: now i saw that you said to get 3s novak smart stop Last edited by theclimber; 11-09-2011 at 02:21 PM. |
11-09-2011, 02:27 PM | #10 | |
get a bec and put a 19t on it with 3s i ran my rooster with a 3s with no cutoff and it was fine cuz the reciver i have cuts it off if the power drops to low it will get warmer with 3s but wont hurt it | |
11-09-2011, 05:02 PM | #11 | |
okay i didnt know that i would still get the cutoff unit just to be safe. | |
11-09-2011, 05:25 PM | #12 |
Newbie Join Date: Aug 2009 Location: vacaville
I agree with the need for cutoff, I have had really bad luck killing LiPo's
11-09-2011, 07:50 PM | #13 |
i agree get the cutoff
11-09-2011, 10:07 PM | #14 |
Pebble Pounder Join Date: Nov 2010 Location: Everson, WA
I run the early Novak Goat with the 18.5 motor. It works great with the stock pinion. I have broken two axle pinions, but I was in some bad binds and tried to power out. If I could buy another one, I would have gotten the newer Goat 3s so I could run a 3s lipo. The motor is a bit notchy at slow speed, but never to the point of breaking traction. |
11-10-2011, 07:43 AM | #15 |
RCC Addict Join Date: Mar 2010 Location: Colorado Springs, Co
I ran the novak goat 18.5 system on my creeper with no issues for over 2 years. Just make sure you upgrade the drive shaft or if you get in a bad bind, you'll snap the drive shaft almost every time. Punisher shafts will be key. Aside from that, it is a great set up! If I were to do it again though, I would get the 21T Balistic. Just make sure you gear mesh is perfect, if it's too loose you'll strip the gears under hard bashing. Keep that gear box greased!!!
