ratterd's Venom build 1 Attachment(s) I've been here awhile, this is my first build on RCC so bare with me.I'm looking to retire my TLT sportsman rig with a Venom creeper.The baisics are done,Tranny,sideplates and lower links. |
Re: ratterd's Venom build 1 Attachment(s) Here's a list of mods that are going into this build The H R parts are rear lockouts,front C hubs and a AX10 front difflocker. The Atomic parts are the Atomic rear difflocker. The Axial Parts are the over drive ring and pinion Vanquish high sterr 0 ackerman knuckles RCP wheelyking MIP CVDs Thats it for now. |
Re: ratterd's Venom build this mite be prety cool. i know you will do some custom stuff to it hope you have it ready for the next comp."thumbsup" |
Re: ratterd's Venom build Quote:
Re: ratterd's Venom build 3 Attachment(s) Well the rear axle is done it only took 1 shim on the pinion to take up the extra movement there.The H R lockouts was a different story though when thay were put together the bearing inside the lockout would slide in and out about 1 1/2mm on both sides,I used 3 traxxas teflon washers on each side on the stub axle then put the axle through the lockout, problem solved. |
Re: ratterd's Venom build I am waiting with baited breath for what you do with those wheelie king CVDs......... |
Re: ratterd's Venom build 1 Attachment(s) Quote:
What I've done now is changed the stub ends from WK to the RCP TLT stub ends and several hour of serching for the rite bearings to use in the VP knuckles they will work,But as for being sumwhat simple and cost affective I do'nt think so but other might,Also the shaft end needs to be shortend and the flat sections need to be cut on them. |
Re: ratterd's Venom build That was the problem i was having, everything that looks like it might work well had the wrong stub on it and once you swapped stubs, the cost was over my limit. .........sooooo the pig of a bronco is going SCX10 axles and the creepers are moving in under a much lighter tuber ;) |
Re: ratterd's Venom build 3 Attachment(s) Well I got a little bit more done today,I got the HR steel AX10 diff locker shimed in with the Axial over drive ring and pinion on it.(pic#1) The 2nd pic is the wheely king/TLT MIP shafts and stubs instaled. The 3rd pic is the finished front axle with the HR Chubs,vanquish 0 ackerman knuckles and D Lux no slop bushings. |
Re: ratterd's Venom build 2 Attachment(s) I got the upper link mount made and installed today. |
Re: ratterd's Venom build I like the link plate being up high like that. What are the benefits of raising them up and separating them though? |
Re: ratterd's Venom build Would you be willing to do up a parts list with part numbers for the front axle conversion? whats the ratio difference front and rear? |
Re: ratterd's Venom build Flex steer isn't an issue for me at all with 4WS but the torque twist would be nice to get rid of. With these being shaft driven, it can only be countered not completely eliminated. I just moved my upper rear links to the outer portion of the stock tabs and that helped quite a bit. Your design is wider and may be adaptable to fit the servo in there as well as allow more uptravel with my battery placement. I look forward to seeing your build and I really want to see some good high torque video of it as well. |
H-R Parts and numbers unibody shd differential lock ax10..SCP125R black alum. c-hub creeper..CRP1901 HPI parts and numbers washers 10x12x0.2mm..Z892 AXIAL parts and numbers Heavy Duty Bevel Gear Set 36t/14t..AX30401 RCP Crawlers parts and numbers Wheely King CVD axle by MIP..SKU#WK10220 2x TLT stub axle by MIP SKU#10202 2x Bearing 6x11x4 2x Bearing 6x10x3 Vanquish 0 ackerman AX10 high steer knuckles(I do'nt have a part # for these.) I was not able to find any 10x15x1mm shims(I had to make them for the front locker) Please Note that there is alot of cutting and grinding for fitment for this front axle. |
I am starting to think this mod would be worth the money. I can run Axial axles and have these laying around or i can invest some time/money and get them functional. You have seen as I have that the Front is trouble area while the rear can be welded up and built with the stock parts. |
Re: ratterd's Venom build I would really like to do some testing on this front axle before anybody desides to build it,I think the weak point of the axle is that 6x10x3 bearing. |
Re: ratterd's Venom build 1 Attachment(s) I did'nt use the pins that come in the kit for the hexs I used the traxxas set screws that have the pin on them thay are used on the traxxas pinion yokes.I drilled the hole on the stub axle alittle bigger for the pin and slid the hex over the hole put the pin in through the hex and the stub axle and tightend it up.It made for a much closer fit to the knuckle. |
