Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > XTM Crawler
Thread: XTM Chassis and other questions
Old 11-19-2009, 08:11 AM   #1
Default XTM Chassis and other questions
Anyone know of any good chassis that might work for the XTM ?? The stock setup is pretty weak, I keep bending the side plates... I have 2 ESC's and they dont always come on at exactly the same time so it brings out the slop in the stock setup. I want a tube chassis, but anything good I will be open to. I think I want bent links also. Is it a bad idea to bend the stock links ? I have 2 quark 33 esc's with 2 HH 1000kv crawl masters i think they are called.. and I'm running them on a DX7. I set them to have the biggest nutral points as possible and it works OK, but I dont like the huge reverse delay. Can some one tell me whats a good ESC for running 2 motors and maybe some mixing ideas. I had it so the rear throttle and steer were on the left stick and the front on the right. So i could control everything individually, but it was far too difficult for my coordination lol. Now I have the throttle mixed with elevator for the 2 ESCs and a dual rate for the elevator so I can shut it off. and I also mixed the aileron with rudder so its 4ws and I put a dual rate on that as well so i can shut it off, or shut the mix off for crab walkin or whatever I want to do.
Ok, maybe that didnt make much sense so heres my 2 questions more clearly
1. Where can I get a super class chassis ?
2. Whats the best brushless ESC's between 18A-35A for dual esc/motor setup
3. is there a thread on the DX6-DX7 setup ? I found a couple on 3 and 4 channle pistol remotes not DX7
prozak is offline   Reply With Quote
Old 11-19-2009, 02:48 PM   #2
Sometimes, I make things.
crazyorigin's Avatar
I found this in a quick search:
Programing Spektrum DX7 for Clod
crazyorigin is offline   Reply With Quote
Old 12-20-2009, 04:07 AM   #3
I know what you mean I did those configs on my RDS 8000 pretty nice to have with just a toggle of a switch init? Any other kind of mixing you did with DX7 ?
I'd like to get ideas to do some more experiments with my radio !
Le0Heart is offline   Reply With Quote
