08-09-2009, 10:05 AM | #1 |
Rock Stacker Join Date: Dec 2008 Location: mission viejo
| Got one too..
Weekend project..got it at 199 buck for super class..good deal... It was yellow box but I welded gears for make sure for it.... I rewinding novak 55T to 40T because so slow.. still good tork at 40T. It better looking at axle body so.. |
08-09-2009, 09:40 PM | #2 |
Quarry Creeper Join Date: Dec 2008 Location: Punta Gorda, Flo-rida
Looks good, i got the one in the yeallow box to, never had a problem with the gears but shreaded an axle shaft the second it started crawling on the rocks. I need to put some lower turn motors in mine but for now the 55turn will have to do, me and winding my own motors = 2 ruined motors |
08-09-2009, 09:50 PM | #3 |
Rock Stacker Join Date: Jul 2009 Location: worley/boise as of aug 20
that wheel in the back is sick
08-09-2009, 11:38 PM | #4 |
hihi Sorry about my old axle body.. It from my very first rig. All other rig I change to home made Tube body so.. I am planing to build one for this Super X.. I will post pic when I done it. rewinding motor is so easy and simple. not at first time do...hihi Yellow box gear...I take out and inspected. It is mikimouse job!!!! before weld gear I teped It move.. this condition faltout is nomal..why they keep makeing gear chip way? Whatever.... I add one more servo for better streeing Streeing link gard need so bad so part from body mount post bolt to servo mount post.. Last edited by ke6geu; 08-16-2009 at 07:42 AM. |
08-14-2009, 11:11 PM | #5 |
RCC Addict Join Date: Mar 2009 Location: In a very dark cave can't you tell...
| Great Work
Thats a great looking rig. |
08-15-2009, 08:20 PM | #6 |
Quarry Creeper Join Date: Dec 2008 Location: Hawthorne, CA
I love the idea of the two servos... Do you think it's going to give them more strenght? I liked the body you had on it. Looked bad ass. My X is still on top of a shelf waiting for a money pit. Here in Cali it doesn't rain anymore, when it does ill be he first one to the end of the rainbow looking for the treasure.
08-15-2009, 08:50 PM | #7 |
One servo feel really week for this bigthing. two is alot better strenght, but you have to connect right two servo link two servo not fight each other. help each other you know what I mean... Today I did worked on shock mount.. this is simplest way to do it.. works alot better then before.. Now I can see the front and back shocks now.. Little mod body bad seat better too.. I bent the low links and move one hole to outside. Last edited by ke6geu; 08-16-2009 at 12:49 AM. |
08-15-2009, 09:32 PM | #8 |
Extremly good looking truck. Nice set-up for the shocks. I put teflon on edge of the shock cap and cylinder so when i put the cap it won't leak. its work so far. you just have to make sure you bleed the shock before you tighten it because if you dont the bottom part of the shock will shoot out.(Speaking from experience). IMO new shocks are not needed, you just have to have a little imagination.
08-16-2009, 08:30 AM | #9 |
Good idea when I got it two shocks bad leak from top cap. factory assembled top cap tite too hard. top cap seal damage If cap too tite... If leak from bottom oring seal clean real good put it back will solve problem. So far I spend... XTM kit $199 sale Novak ESC combo $109 Extra motor $25 3 servo T-Pro MG995 Metal Gear $9 x 3= $27 ( I dont know why someone buy over $100 servo?? MG995 is good too..they all brack...) Radio I had one for my airplane. DX6 |
08-16-2009, 01:29 PM | #10 |
Nice setup.
08-16-2009, 01:31 PM | #11 |
I still have to buy a radio but when mine is ready we should g2g. If you still have yours.
08-19-2009, 12:13 AM | #12 |
All done for this project... Hand made aluminum body. 6 LED head light looks cool bright. each 2 Led connect serial and connect to motor so light on only at foword. Last edited by ke6geu; 08-24-2009 at 11:27 AM. |
08-19-2009, 08:01 AM | #13 |
RCC Addict Join Date: Dec 2005 Location: Tucson
Look good but i scared to buy one. because all there problems. I'm between x-crawler or Rc4wd super bully's? |
08-19-2009, 03:23 PM | #14 |
| For $200 i would go with the bullys, dont get me wrong i like the x-crawler, but im afraid to put it in a bind, the solid axle shaft its not a comp friendly design.
08-19-2009, 06:08 PM | #16 |
Very nice but out of stock... one axle cost $99x2 streeling kit $35x2 all link$?? weels and tires $200 chessi $?? this and that with out eletronic I assuming you need $700-$800 same as kelly kit... XTM is not bad just 4 gear need to weld. that is it.. all for $199 Last edited by ke6geu; 08-19-2009 at 08:46 PM. |
08-19-2009, 06:46 PM | #17 |
| Granted it would be quite a bit more to set up but will most likely be more durable, But if you break an axle shaft on it you wont be able to Finnish that course or any other course that day for me at least i havnt been able to remove pins without a vice.
08-21-2009, 07:45 PM | #18 | |
Release your anger.. Join Date: Oct 2006 Location: North American Union
From this perspective,everything on the XTM sans the axles is junk. On a side note: Most guys are somewhat apprehensive towards the axles. The XTMs are based of a older RC4WD axle line name "Raptors." If you search for Raptors you'll see their record of breaking and being too high geared for crawling. .................................. Back to the point: Either way to be competitive would require a major overhaul. So you spend several hundreds to get a XTM in shape and hope they hold up at the end. Not to mention spare parts or go to a sturdier design for the same price. | |
08-22-2009, 05:18 PM | #19 |
ordered Super bully's instead.
08-22-2009, 06:09 PM | #20 |
