Post pics of your 2.2 Comp rigs and specs!
Brandon
Im Brandon
Vendor
Colfax, CA
Post up your rig and specs. CA needs to represent 8)
If you dont have any pics of your rig but have attended comp recently check here: http://www.nor-calrcrc.com/gallery/view_album.php?set_albumName=Crawling
Keep the chit chat to a minimum and I will talk badger into making this a sticky "thumbsup"
Specs:
My 2.2 Blackjack
Sincity/RCP blackjack chassis
Tlt axles
Axial tranny
55t lathe
3s lipo
5995 hitec servo
Axial beadlocks with TCS :flipoff: rings
Worn out Losi claws
Top secret anti dig setup :lol:
Heres my cheapo Jeep.
Specs are:
SW2 chassis
bone stock tlt axles
pede trans
55 turn lathe motor
TQ3 tx/rx
LRP waterproof esc (has 3 second reverse delay :roll:)
worn Masher 2000's
HPI Jeep body
645mg servo
and stock tlt shocks :flipoff:
Yeah its a piece of crap but somehow i still do pretty good.
2.2 Comp rig:
Custom chassis
ax10 axles
ax10 tranny
rooster crawler
55t
hitec 5995
claws
droop front/ sprung rear
Project TINY
3/16 DOM tubing
Panhard 3 link front and rear suspension
TLT axles (one slightly modified)
Losi XXX trans
55T motor
Rock Crushers / Mayhem Engineering beadlocks for rock racing
Rock Claws / RC4wd beadlocks for crawling competitions
HS5955 servo (squels like a mother, but turns the wheels)
"Sancho"
SinCity's Black Jack chassis
tlt axles
Novak's 55t lathe
Novak's Rooster Crawler ESC
Hitec 645 servo
Spektrum
createacrawler's "Sinners" bead locks
Losi Rock Claws
3Racing mini LST shocks
Ive been reading on RCCRAWLER for Quite a while, and finnally decided to build one. So here it is, my first crawler.
SW3 Chassis
Axial Axles
Losi XXX T SHOCKS 60 wt oil in each
R2D with DIG
Crawlmaster Sport
Mamba Max
Novak BEC
RC4WD Wheels 3oz of lead in each front wheel 1.5 oz lead in each rear wheel
Kreepy Krawler Red Wide in front, Pink Wide in Rear
Losi Rock Claws
ACE 1313 Steering Servo
Airtronics Rock Crusher for Dig
Mine - yellow bug:
P4 Chassis
Tlt axles
R2D trans w/Hitec 5645 for dig
Axiom 55t motor
Mamba Max
JR 8711 servo
CC BEC
8 cell Elite 1500's
DJ's (my 12year old son) - red bug:
Modified AX-10 chassis
GPM 110mm shocks
AX-10 axles
R2D trans
Integy V10 handwound 50T
Mamba Max
Hitec 5955 servo - steering
Hitec 85mg servo - dig
CC-BEC
6 cell elite 1500's
Mine is always undergoing revision of some sort, considering it's COMPLETELY custom. The only non-modified stock parts are plastic diff cases, rear R&P, and rear link/shock mounts.
-narrowed WK axles (by about 1.3")
-front CVDs
-RC4WD rear steer lockout adapter
-MSD Top Gun beadlocks (the reason why I narrowed the axles)
-Masher 2000s
-KMS 2826/6 730kv outrunner
-direct drive, geared 6/64
-Mamba 25 ESC
-custom chassis
-Traxxas Big Bore shocks with XTM X-Cellerator throttle return springs as internal springs
-custom BTA steering
-Hitec 5955TG
-cheap 6v 3amp UBEC (works well enough)
-3s 2100mah Lipo
-Nomadio React radio
-T/E-Maxx driveshafts
-all custom links, rears are obviously bent (looking to remount the front shocks and make some bent front links as well)
Needs a more low profile body than the HPI Bronco it's currently running.
And the body that's currently on it (but an older pic):
slickrock mafia comp rigs.................
custom tube chassis
r2d trans
tlt axles all alum upgrades
losi rock claws
rc4wd beadlocks
rooster crawler
65t
scorpion
r2d trans
rooster crawler
rc4wd beadlocks
alum upgrades
rockstar body
Raptor2 2.2
Here is my narrowed Raptor2 torsion chassic rig. I am running 55 turn motors with 6 tooth pinions. Mamba Max and an 11.1 volt lipo with Castle BEC. The radio is an Airtronics MX3. Let me know what you think.
STUFF:
Axial axles
Axial tranny
Rcp staright axle adapters
Rcp straight axles
Integy 55t
Mamba Max esc
Airtronics tx & rx
custom chassis & links
Hitec 5995 servo
Xtm shocks
Rpm wheels
Losi claws &
grappler body
SW3 chassis
AX10 axles
R2D
7t Cobalt
3C Lipo
DX3R
BL02N
Losi Claws
Mamba max and CCBEC
645 and 5595
TCS aluminum 4-link plates
Aluminun Cs, knuckles, and lock outs
Losi XXX shocks
Reign J2-tt Chassis
TLT axles
Old school Moab tires w/ RC4wd beadlocks
R2D trans
35t Integy motor
Novak Crawler ESC
Hitec receiver
Hitec servos
Blackjack Chassis
TLT Axles-
RCP & RC4WD R&P's
MSD C's & Lockouts
RC4WD Straight Axle
RCP CVD's
R2D trans
Pede Shafts w/metal yokes
HPI Shocks
Mayhen DP's
Losi Claws w/red Kreepy's
HH Crawlmaster
Mamba 25
TQ3 (DX3R coming soon)
2100 3s Lipo
Htec 5955
Custom Links
RockstarBody
Here is my 2.2 Comp Rig
It's basically a stock RTR Axial with:
Homemade Link Plates
High Clearance Lower Links
Integy 45 Turn Lathe Motor
8 Cell Saddle Pack 1500 Mounted On Axle With Homemade Battery Plates
Homemade Aluminum Tie Rod
Axial Super Soft Springs Up Front
Losi Rock Claws
Two 1/8'' Holes Drilled In All 4 Rims
8 Star Cut Axial Foams Up Front
No Foams Out Back
Pro-Line '80 Chevy K10 Body
Custom built Tuber
Here is my own design Tuber 3/16 tube
AX-10 Trans 55t lathe motor
Tekin FX-R
3S lipo
Poulson Axles
Hi Tec 5955ts
McCrawlin that me
specs
VF Sling Shot chassis with links
Revo shocks with yellow springs
Axial Axles
Axial Tranny with VF dig
Integy 55t lathe motor
Mayhem Spiders with Panther Tires custom hybrids in the rear and 1 1/2 panther foam up front
TCS Four link front and rear
RCP c hubs, knuckles, straight axle
Hitec HS 5985MG steering this rig
apogee 2200mah lipo
CENTRAL VALLEY ROCK CRAWLER BABY
Scorpion
Losi Crawler Shocks
Lose Crawler tires
Rooster Motor and Speed Control
RC Solution Roll Cage
stock links (aluminum ones this month)
Axial Scorpion kit
-ckc crawlers stage 2 kit
-Bent links front and rear
-losi rock claws(added after pic)
-upgraded drive shafts and yolks
-integy axle spacers
-lots of mods
CDW 2.2 comp chassis
Novak "Rooster Crawler" esc
Novak 55t motor
Spektrum DX3
Stealth B-4 w/ Taylors hobby locker
CAC "Sinners" w/ Losi "Rock Claws"
