Post pics of your 2.2 Comp rigs and specs!
^^^^^^^^^ EZY RYDER's pictures^^^^^^^^^^^
Here's mine.
well here is a few pics of mine
nothing too special
rooster esc
65turn
4 linked
rc4wd rims
Rubicon tires
rc4wd punsher shafts
my back up rig-
akrcc test chassis
axial axles/trany/front shox
jr tx/rx/8711servo
upgraded metal trany gears
hr-spur
novak rcrawler w/ 55t
integy drives
smc bent links all around
integy rims/puttytats/pl-body
trax-upper links
rc4wd rear lockouts/front c hubs/ knuckles/rear shox
2=1000mah 2s lipo parl.
everything mounted on the front-esc,servo,lipox2
Wheely King Conversion @ Crane Creek
Here are a couple of pictures of my Wheely King Crawler up at Crane Creek regional park(my favorite place to crawl). This is an awesome place to crawl - roughly 1/2 mile of rocky creek bed with just the right sized rocks for crawling and only five minutes from my house! Unfortunately it will all be under rushing water soon. Here is the current setup of my WK:
96 tooth Spur
12 tooth Pinion
55 turn Novak Motor
HPI Cralwer Conversion
Chassis reversed
Losi mini crawler speed control
50/50 suspension(1.5 inch springs inside)
Stock tires and wheels
5oz Weight on each front wheel
Axle mount Servo plate
HPI Jeep Rubicon Body
My AX10 ARTR RIG
Axail AX10 Crawler
Changes Made:
Mods:
Added stick on weights to F/R wheels.
Counter Sunk Screws on the front side
of the front axle to get more steering.
Added ¼ inch of fuel tubing inside of shocks
to lower ride height to 2 7/8 inches.
Flipped the transmission around.
Moved the body as low as posible
Removed stock battery tray.
Upgrades:
Losi Rock Claw tires.
MIP C Spline Drive Shafts
MIP CVD front axles.
Axail Soft Springs in front.
Black 30 degree lower bent links F/R
EEM Dual Reverse Triangulation Delrin Skid
TCS Delrin 4 Link Plates F/R.
TCS Delrin saddle pack axle battery mounts.
TCS upper link plates F/R.
Screws replaced with hex screws.
Electronics:
Castle Creations Mamba Max ESC
Cheap Battery Packs
1500mah NiMh 6 cell saddle Pack Battery
Mounted on the front Axle
Integy 55t motor
Still to come are a dig and a new body.
A Castle Creations BEC
And will be going to 8 cell saddle packs for a little more get up and go when it is needed.
Then
Now
Started out as a bone stock AX-10 with an ok Hightech radio. Goat Brushless system and big 3400mah sub c pack.... It sucked so I had to build one.
Now I built my self a Tube Chassis
Goat brushless w/ 2700 kv motor 14t pinion/87 spur
2/3a 7 cell saddle packs
Losi Claws
DNA dig w/645mg Servo for dig
Hightech 7955TG Coreless Steering servo
Castle BEC at 6.4 volts
Spektrum DX3R Radio
Customer Built upper four link plates
MIP front CV Drive Shaft
STNC Knuckes/Inner C's and Skid
RC 4WD rear Lock outs
Uppgraded Spools in diffs
had Integy Shocks but they would not stop leaking went back to stock springs with a little special tuning....
Did not have my 2/3 a Packs Made yet. Did my first comp with the Integy's and the big sub c's
this is what it looks like now
here is mine
-BLACK WIDOW CHASSIS
-MAYHEM WHEELS
-ROVERS
-DNA DIG
-DX3
-CC BEC
-CC SIDEWINDER
-INTEGY V11 PRO 65T
-1320 3 CELL LIPO
-INTEGY SHOCKS WITH 70WT OIL
-JR 8711 STEEREING
-HITEC 225 MG DIG
-9 OZ IN FRONT (EACH)
-3 OZ IN REAR (EACH)
-ALLUMINUM C AND HIGH STEER KNUCKLES
-STRAIGHT AXLE AND ALLUMINUM LOCKOUTS
-MY OWN CUSTOM LINKS
ax10 stage 2
ax10 kit, CKRC stage II kit
Novak brushed rooster crawler motor/esc set
HPI jeep body
Traxxas EMaxx steering servo
CKRC front batt/servo plate
15oz weight in front wheels, none in back
Traxxas controller/reciever
Heres mine
AX10 SWX Chassis
Bender 4 link plate
tekin fxr/55t combo
ckrc bta steering
mayhem DP beadlockers
rovers
losi 4' shocks
Here is my comp rig.
Novak Rooster
Matrix 65T
Stage 3 Racing Trans/Dig
Panthers W/ 5.5 Foam
Hitec TG
ProLine RockStar body
And here are my play toys.
