Link Legnth
Flash
Huntington Beach
Hi all,
Im a newbie with crawlers. I got the J2-TT chassis. I have the axial drivetrain in it. My issue is with links being to long. Wat is the best way to legnthen them. Should I remake new links. How do I go about this.
Thx :?:
Sorry I need to shorten them. Im sitting at 13.75 in wheelbase. Should I take out 1 in up front and 0.5 in in the rear.
Thx
Thx
depends if you wanna change the weight bias to the front or rear. more weight in the front is the norm, but I feel a 50/50 setup is easiest to tune.
If your links are delrin, cut off the desired amount, redrill for the correct thread size, and replace the rod end.
I am curious as to how you ended up so long in the wheelbase using the stock lengths???? I just did the same build 2 weeks ago, and used the stock bent lenghts for the lower links, and used custom solid 60mm upper links just to tilt the pinion angle up a tad for better driveline geometry. With these stock links, I ended up at 12 3/4"....so I just shaved 1/8" off of each lower link....thus bringing me to 12 1/2".
