JAM MaxAmps.com
When you say a small pack, what is a small pack ?
I thought mah= run time, the bigger mah the longer run time you will get.
The C and burst rate is what I though a person should be looking at?
Yes mAh = runtime but in general the more capacity in a pack the higher the amp draw is that the pack can handle then you add in a higher c rating and that same pack can handle more amps.
Jason
