cartronicshn
Hi John, you have paypal for that order we spoke over the phone, thanks again and nice talking to you"thumbsup"
i have a problem about castle link program. i did try install castle link v3.11 (which previously installed v3.04), then connected with castle link kit and sidewinder. i got the usb connection status is green and the device connection is green too. but i haven't got any setting tab. just stuck in castle link picture, like picture in 'About' tab.
luckily i have backup from previous version v3.04...then i uninstall v3.11 back to v3.04 and have great result like before. i got problem too with the firmware update for sidewinder. i only got v1.16 and v1.17. which is the newer version is v1.18.
do you ever have problem like that? how can i get previous version? do you always update all castle products or not?
i have read on castle's site, but i didn't get clue for my problem.
My fiance has an axial AX 10 scorpion and he has purchased an aftermarket plate ( I think it is a servo plate). In order to use this plate effectively he needs to move the links to the inside. Can someone tell me how this can be done or is the a link that goes to a step by step on doing so. A gentleman at the hobbie store said there was a step by step on rccrawler.com/techsupport, bt I have been looking for over 2 hours and have found nothing. Any help or advice will be greatly appreciated. Thanks![]()
With a berg or clod, and high turn brushed motors, does the freewheel setting on a Dig really do you much good? Doesnt seem too...
Is it better with brushless motors? In other words, is there less spinning resistance on a brushless motor that is not powered?
John got a weird one for ya...
mm been working perfectly since I bought it almost year ago. Pull out of my old comp rig. Put it in my new one. The only thing I did to it cut the stock switch off since I broke off the tab to on/off the switch and soldered the wires back together so closes the loop. When to turn on the rig and it power up and get steering and dig servo. But it will not arm itself and I get no throttle,everything else works though.
Hey jrh is this still on the back burner or is it still in development. I am wanting one and looking foward to this
http://holmeshobbies.com/product.php?productid=153&cat=17&page=1
Thanks
chad
Hey JRH,
When are you going to have 35 turns back in stock? Also what motor do you recommend for a Slash with stock esc.
Thanks,
RPMJ
will the 454 fit in an AX-10 with stock tranny? will it work with the Visionary Faberications motor plate? will i need your motor plate as well?
will 7 or 8 cell 1500 elite saddle packs work for power with a sidewinder?
CASTLE BEC Order
Which output voltage do I use?
I'm adding an Ipod stereo amp to my crawler, 6 watts, it takes 4 AA batteries =6+ volts
but the ac/dc adaptor plugs into the back where it says 9V input
Which Voltage BEC do I need to order:?:
Also how do you remove the annoying beep noises from my Mamba max /BM16 setup :?:
Thank you for your time"thumbsup"
Rian
You could run 6v to the battery wires, or run 9v to the AC plug on the back. Just depends on how clean you want it to look.
I have an AX10 with a Mamba Max and 7T puller motor. I have 2 850 venom li po packs. 2 questions.
1. Can you recomend 2 packs that will meet the power needs of the 7t motor. I only get about 20 minutes out of this beast and would like more time. I can fit the 1100 mah lipos on the axles, but thats about it, and I do not think they put out enough amps to keep up.
2. Can I charge 2 li po packs ( my 850's together ) if I set the amps to max out at the total mah of the packs (ie. 800 mili amps for 1 pack, 1.6 amps to charge 2). They are wired together now, I have to take them apart to charge them.
Thanks
Ted
Hi John, You have any idea when you might get the Castle Mamba Max back in stock?
Do you have or able to sell a cc sidewinder with a pro 540 35t in a combo?
I emailed you about going brushless ,but to get what I want out of it perfer to spend the $$$ else where
JRH, I recently bought your EOS0606i charger with balancer
I bought a 2 cell lipo battery
2150mah / 20C / VP racing battery
the plug on the battery, female 3 hole, dosen't mach up with the balancer 2s slot, it has five pin. Do you make an adaptor for it?
also I plugged the cables in, then lipo, then ac (in that order)
pushed batt type button once
it displays:
Lipo CHARGE
C=1000mah 2s
i hit the enter button, 1000mah flashes, I just increse to 2150
and hold down enter to start charging right?
I charged my NiMH's, it is soooo quite compared to my 969 super brain, I didn't even think it was running"thumbsup"
Thanks
Dewayne
Hey John I ordered a 7t a few months ago and now finally getting around to using it. (full size crawler got the best of my summer) I see I should be using a 20C 3 cell lipo, I have a mamba max and bec I could use but wondering if there is something smaller that I could use that will take that much power. Looking for the best performance and if it means using my mamba I will. Thanks John Hope your having a good weekend answering all our questions.
