Xtant3150c
Well finally got my MRC in this past Friday!
Had 18R racing that night though and a busy weekend with a Comp yesterday.
So yesterday was the first day I actually got to run it! And even then I was not the first person to drive it :shock: I let DTP give it a go to help push him over the edge to get one! And it worked he called the lhs right after running it and put a hold on the one they had left! "thumbsup"
For it's first run I only added 1oz. of weight to each front wheel. Did'nt want to over do it and kill the servo.
Ran pretty good with the obvious problem being the stock pack up on top!
We are going to be adding a 1.9 Comp Class next season! So despite thinking I would run it around stock for awhile that changed after I got home from the Comp! :lol:
Got started on the free mods, trans flip, lower electronics and mount the shocks to the chassis. Picked up some Axiall 60mm post to brace the chassis. Still need to make some mounting trays for the upper links.
Will be using a Thunder Power 2S 1320mah pack with stock electronics. Stock servo will also stay for now but will most likely be changed out sooner rather then later.
Here's some in and out of box pics
And the mandatory box pic ;-)
