John,
Do you have any updates on when the Berg pinions will be done? I have on order 2 of the 8 tooth pinions. Thanks
I should have had them by now, I was told they were shipping early next week. Time to call again and see what the hold up is this time... What a mess on these pinions.
I'm running a AX10 with a dig and a novak rooster 55t motor .I would like to up grade . What would you sugest & do you have a price list
All of my prices are listed on my website. The first think you could upgrade would be your voltage. A two cell or three cell lipo would really give you some good punch. I know the rooster isn't rated for a three cell, but guys have run it with an external BEC. More voltage is a great place to start at any rate.
i'm looking for wheelspeed and runtime. i have a axial artr with mip driveshafts,flm chassis,stock tranny,axles running 7cell 1500 nmh front and backup 6cell 2200 nmh. what would you suggest for motor,esc and batts. thanks.
I am big on lipos. I would run a 45t motor on 3s 2200 lipo with a tekin FXR or sidewinder ESC.
Just ordered some items including a hyperion duo 2 charger! Thank you for answering all my questions, cant wait to get my items john. BTW do you have any discount coupons currently?
I think the ESC coupon may still have a few redeemings left. Thanks for the order!
Hey JRH, can you check on shipping status on order #2975, placed on 2/12 please. thanks
Packaged up over the weekend, but shipping doesn't run until tomorrow. You should have it by the weekend!
I am looking at the Hyperion 0606i charger on your site, will a 6A 12v power suplly be enough for this charger or will I need to get a higher amp power supply. Also what do I need to order to make this charger good to go? Thanks.
6a will cut it. You need 50 watts to get full capacity from the charger. Pick up a balancing multi tap for whatever brand batteries you have and you will be ready to go! Extra bullet plugs and wire is always nice to make different charging harnesses with too.
Ive been looking around your site, and searching the vendors section, but i cant find any detailed specs on any of your motors. Do you have charts or anything on them posted somewhere listing the output numbers? Im interested in the crawler motors, the specs on the faster stuff from Castle and Fegiao are already available elsewhere.
Mainly interested in:
Power output
Current draw (hopefully at least at no load / average load)
Torque vs RPM curve
Peak Efficiency
Also curious on what springs you use and if you adjust brush tension before you sell them.
It would be nice to be able to compare your motors to some others out there.
Is there a specific motor you are interested in? My brushed motors use 15 ounce springs, and the rest is totally dependent on the motor. Power is dependent on batteries, current draw depends on voltage and load, etc...
Torque vs RPM curve for a permanent magnet motor is always a linear and opposite relationship.
If you want a motor for a certain vehicle I can help you there, but a rough and ready estimation is that a heavier motor has more power.
