kish
are the p94s 35t still going to be in for tomorrow? if so, I'm getting one. how soon can I order one?
Hey John,
I got a tech. question for you. Ok tonight I plugged in a test battery which was a 9.9v 2300 mah A123 battery. Now the motor turned like once then just makes a humming noise and got warm to the touch before I turned it off. I'am running a Tekin FX-R, CC Bec, with a 12t pinion. What do you think the problem might be.
The cobalt 500 is smaller and has the same speed then why dosent every one get them instead of the 7t? Can i use a rooster with it? If it smaller then a regular motor it will fit in my truck. But it uses more power then a 55 turn?
I just searched through your threads more in depth and found that you said there isnt really a difference between the cobalt 500 and a 540 integy 55 turn. So its not really worth for me to switch? Whats the advantage?
I just recieved my 2 Poly RC 2s 7.4v 22oomAh lipos and was curious of what amp charge rate you reccomend? All my other lipos(Xcaliber, max amps, ect.) have it on a sticker that was on the pack when I bought them.
Hey John, long time no see!
Couple of easy questions reguarding some lipos. What is the real performance difference between the HH 1300 3s, x-caliber 1650 3s and the thunderpower 1320 3s?
Also, I'm gonna be running an RR2/Mamba 25 in a 1.9 scaler with pede tranny and tlt axles. What do you recommend for gearing and battery?
One more, I've gotta little outrunner I bought a while back, it looks like a bm-16 in color, but I think its smaller, maybe a bm-9. Its Gold on the ends, grey in the center. I'll be running this one through an R2 tranny and wk axles. Will the quark 33 do ok or should I use a mamba 25 with it as well. Can you give me a battery recommedation for this motor and possibly gearing too? Thanks in-advance. I'll be making an order pretty soon!
Tom
John, I saw you completed my orders #2908 and #2936. Did you combine them? I saw the shipping refund"thumbsup"
Hey John,
John if you could i would like your oppinion. Im planning on a 7T puller motor with a mamba max on 11.1 in my summit. Do you have any ideas about running a puller in a revo size truck. Im aiming for crawlability with still being able to bash around with the 2 speed tranny thats in it.
Thanks much
John, I am wanting to get a couple of 2c Lipos for my rigs to try out. I am curious about the run time as compared to waht I have now. I am currently running a 3300 6c stick in my scaler with a 27t and stock axial trans(@30-40 min RT) and an Elite1500 6c saddle pack of yours in the comp rig with a 55t and stock axial trans(@45 min RT). Would I get about the same rntimes with the Poly RC 2200 packs or will I need to get a higher Mah? Thanks, Jeff
Hey JRH, can you check on shipping status on order #2891, placed on 1/26 please. thanks
I get nothing from the tracking info. It shipped out long enough ago that you should have gotten it. If it doesn't come in a few more days hit me up and I will resend a package for you.
