CROW.....With new shoes.
Reflection
TEAM MODERATOR
Moderator
Tennessee
Lets see what all the hub bub is about with these damn Bergs that drive themselves.:lol:
Specs for now....
AKRCC chassis
Machined bent rear lowers
Cheater,I mean Berg axles clocked 25 degrees
PolyRC 2200mah 3 cell from Holmes Hobbies
35t motors from Holmes Hobbies
Castle Mamba max from RCP Crawlers
Castle BEC from Holmes Hobbies
MANLY dig switches from Holmes Hobbies
HS 81 dig servo
Airtronics 359 for the steering
Twin Force shocks limited internally
Losi yellow springs
Panthers on VF Stalkers
I'll be doing a little more work on this later this afternoon. I'll try and get a few more pictures up then.
Looking good Mr. Shafty Man!!
:flipoff::lol:
Are those axial offset wheels?
Yes sir they are. Outside to outside is a shade less than 10.750" A tad wide,but it'll work for now. My Axial rig was 10.250" and I liked it...but could have used a bit more width at times. I may end up buying a new set of wheels if this width is to much.
Looking good Steve. I'm about to yank my hair out w/ mine. I'm trying a rockshow chassis.... and getting all the electronics in that little space and trying to make it look half good is a chore. :roll:
Thanks Harvo. The wiring is a bit of a pain.
Up till about 2:30 a.m. finishing this up. Here's a few more before the electronics went in.....
After all the wiring BS........
I thought these Berg axles were supposed to be strong. Not even one pack through them and the front axle is toast.:lol:
Cleaned the gears of their teeth.
I've had plastic spur gears handle more abuse than I was giving this thing.:roll:
nice build Steve. Sorry to here about your front axle. I like how you mounted your battery in the skid. "thumbsup"
Wow, I was expecting you to say the dogbones or the knuckle even.. Wasn't expecting to hear the gears were the failure point!! I've given my axles hell and then some, the only things I've managed to break are 1 axleshaft, 1 knuckle, bent the ears on the axle tube, and a few bearings lol. Could the gears possibly have been faulty?? Man, now I'm going to have to tear mine down and do some inspecting. Oh well, about time to re-grease them up anyway
Hmmm you had to get a bad one...... Sorry about that, please try again! :-P
What are the brass rods on the sides of the chassis?
Waiting for more......
:lol:
You should know me better than that. I don't give up that easy.:lol:
Those aren't brass rods;-) They are stock Axial shock shafts. For said reasons.;-) Good sturdy bars for a battery strap. Actually,they were just the right length and a perfect fit in the brackets I built to hold them,so I used them:lol:
Looks like some sort of tie down for his battery..
Steve, what pinions are you running? The metric pinions?
RR pinions,and they are the metric ones. At least thats what the package said. Kinda hard to see the difference with the naked eye....specially my eyes.:lol::lol::lol: Bout blind as a bat anymore:lol:
I took all the gears to work,cleaned them up real good and looked them over under a magnifying lens in our inspection room. They were chewed up a bit. I have some super tiny files I use to debur little parts with and used them to clean the gears up best I could. I think they are still useable. Since the rear axle stalls more,I've got them in the rear axle now. I think I'll try and get some actual Berg pinions this time.
Got them. WTF? Enroute doesn't provide grub screws with their pinions?:lol: Kinda lame.
IF I can find 2 good grub screws with the right thread and not stripped out,yes,I'll have this truck ready for Sunday.
Thats weird I was thinking mine came with the grubs :-?
I'm pretty pleased with the way this thing worked on Sunday. TOTALLY different than my shaftie. It was working well until I lost a front shaft on course 3. Guess it's time to put 1:8 scale buggy shafts in this thing as well. They hold up great in my super.
New shoes
Was in desperate need of new shoes. My old wheels worked very well,but allot of the threads for the locking rings were starting to strip. Only having 6 bolts per side,I have lost a bead a few times. I knew I wanted a better bead area with more bolts
Waiting on material right now,but these will be available in the vendors section soon. Couple different offsets available. This one provides 10 3/4" width,which I prefer myself. The other offset should net right at 10 1/2" width....might be able to go a bit skinnier. We'll just have to play with our program and see how far we can push the offset.
I'll tell ya,these HOLD a tire. I'm waiting on hardware right now as I don't have enough on hand to finish a complete set. I ran 3 packs through running a couple of these wheels with only 4 bolts per ring. Never lost a bead."thumbsup" You'll notice the hex area is allot beefier than some wheels. I did this mainly for Greg.:lol: Only guy I know thats broke the hex area out of an aluminum wheel. He won't break these.:lol: There is probably enough meat there to even cut a 14mm hex if someone prefers a 14mm hex,or has a special order.
Sorry the pictures are kinda rough. I'm gonna go run a bit on my rock pile and I'll get a few good pictures.
