JOOTZ
i was hoping you got sumthin new bout the @#!&% DIG. super class sounds good, keep us posted on your build.
i have had very little issues with my dig,,i know exactly what you guys are all talkin about,,when i first put mine in it was dooing all you guys are speaking of,,i pulled it out and massaged some of the moving parts,,i nocked off a very lil amount of material from the locking pins on the plate side,,put angled edges on the plate,,so the pins didnt face a flat wall while trying to dis-engage,,i also removed all the bull shit springs and fuel tubing i was using in the begining,,i have a new dna dig with hd guts in my axial based tuber,,my kyosho dig doesnt work any better or worse than the dna,,im only running a 645 on my rf for dig,,,i guess im just lucky with my rock force,,
Hard anodizing the dig plate is all that was needed.
The latest dig kits from Kyosho are hard anodized.
- DK
I can't comment on the stock dig as I've never fooled with it. From what I see/read,it requires a steering servo to operate it.:lol: If thats what it takes,fine. Gotta do what you gotta do right.:lol: Won't be anything fancy with my dig. It will work very well though.
Thats enough,I don't wanna highjack this thread with BS."thumbsup"
OK I will admit it... The RF is starting to piss me off now with just one thing after another. :-(
[BEGIN RANT]
My plan was to do an article in RC Car about how to set up the Dig on the RF, but that story is history becuase honestly I can't reccomend the upgrade becuase it sucks.
The dig engagement is far from an upgrade on the RF, it's an adventure and a long one at that. Even with a High torque servo handling shifting and I have my doubts that the plastic shifting fork will handle that kind of torque and long-term stress. Bind it up with dig engaged and you usually need to shift into reverse before it will re-engage. Coming from Kyosho... this should be plug and play for the masses and it's far far form that. Sure most of the guys on this forum will take the time to tinker with it to get it working properly, but I have over 2 hours of tinkering into the dig setup and it still only works right about 10% of the time... if it's bound in any way forget about it. Kyosho REALLY should have done some testing before they threw this out there.
I was really hopeful with the RF and with high-speed gears added and a brushless sensored Tekin 21.T system on 3S it's everything you could hope for. Damn I wish I had this much smooth low power and top end speed in my Axial. It is so freaking smooth.
The more I work with the RF the more frustrated I get working around some seriously poor engineering and design issues. Why the heck did Kyosho make the axles so wide... the origianl design was going to be a Super?, Someone had thier thumb firmly planted in a bio rich area? I don't know. But that in turn makes steering suck along with steering knuckles which hit the Panbar link mount less than full lock.
Then there are the too short axle outputs and stock aluminum wheel nuts that won't even seat fully with stock wheels. WTF was this an after though? I can hear it now... "oh crap we need to hold the wheels on with something?" The aluminum nuts are in the trash and replaced with real 6mm locking nuts as they should have been in the first place.
And then...I believe EVERYTHING on the bottom of the RF was designed specifically to catch on rocks. Geez could they hang more crap down there. It's like they designed the mold with Legos and then cast that shape... have they heard of rounded corners? :roll:
Out of the box the thing is impressive. Fairly low CG and pretty well tuned, however there is really not much further you can go with the RF after that without SERIOUS surgery.
Then I look across the table at my DNA dig equiped Axial rigs and they just work. In fact my Slingshot SE is running a pretty much stock ARTR drivetrain with MIP Axles and my SPV2 just put me in the finals at our last local event. Link watching a ping pong game I start glancing pack and forth at the RF and my Axial rigs and have to start asking myself "Why am I putting all this time into a seemingly lost cause when I could be crawling?"
I think my RF project is getting shelved until I can complete a MOA conversion... and maybe then it will be a Super.
Is it a bad thing if I laughed out loud more than three times while reading this?
will they offer just the plate as a seperate purchase,,for those of us who have the dig all ready,,or will it only be available as a full kit??and is there any word on a updated/upgraded shift fork,,lets face it the plastic will only last for so long??Hard anodizing the dig plate is all that was needed.
- DK
I hope to have that answer this week.
The plastic shift fork in mine shows no signs of wear.
- DK
^^^ great info,
to those guys who have 4 linked their fronts any feedbacks on handling ? better or same ?
- DK
I just put in my DIG that I got last week and more often than not I have to back up a bit to get it to disengage, and that is just on flat ground. Should I assume that I received an older DIG kit that wasn't anodized? How would I know if the pieces are anodized? The install was pretty straight forward so I don't think I did anything wrong there. I will try shaving the pins down just a bit to see if that helps, any other things you guys have done to help this issue?
Thanks
Same here and kind of what started my rant in the first place.
I would hold off on shaving pins until we see what Kyosho is going to do. Dean indicated that the new anodized plate will solve the issue and if you shave the pins, you may affect performance even with the new plate installed. I would just sit tight and see what Dean hears back from Kyosho.
I am going on the assumption that Kyosho will stand behind their product and offer an acceptable solution.
i know what the solution is and it's perfectly acceptable.![]()
:lol:
Personally I think it would be the right move for Kyosho to offer to exchange to old plate for the upgraded versions at no charge. Just my two cents.
agreed,,,
