Colby
WOOPOOW!!
So when you use the PunkRC dig switch, do you just leave the throttle spot on the receiver empty? I don't have any of the parts yet, but I'm trying to fiugre out how to wire everything. The dig switch goes into the aux/3rd channel port on the receiver, and the ESC and motors wire directly into the Punk RC dig switch? I am also assuming a single Mamba Max ESC with two brushed motors should work fine on this setup right?
Thanks in advance for any help you can provide.
Well, I do not have the punk just yet, but i have looked it over a million times. Basically you solder the rear motor on, the esc motor wires, and the front motor wires on. Then you plug the dig into the Aux, or 3rd channel port in your receiver. Plug the esc in the channel 2, or throttle, bec in batt port, and steering into the first channel. "thumbsup"
Guys, im headed to the lake for the weekend so post up your questions and im sure someone that knows the answer will help out, or i will get you when i get back. Cya1 8)
