I figured this would be the best thread to post this up in but Jim from Thunder Power gave me a bit of info:
[FONT="]Anyone using lipo batteries must set your esc voltage cut off at 3.3v per cell min. If you use the standard 3.0v that is default in Tekin and most other ESC’s it will cause the batteries to go below the safe threshold and could cause battery damage. The Tekin has a custom set up, however you must use a Hotwire to activate it. It is recommended that the batteries be kept charged 80% or more to get the best performance and not go below the 3.3v per cell threshold. Low battery voltage may also cause glitching and cause loss of control of the vehicle.[/FONT]
