TotoRax
Hello,
I tested my bully axles with a Pimp Cane and Havok frame. But finally I do not like too the balance of the weigh. I did not want to add ballast either. I left on the frame the my crawler WK, of which I like balance.
In front, I use Bully axle, and with the back a AX10 axle and RC4WD R2 trany.
The remainder in image:
BTA
The tire does not rub on the link or the shock (with RockClaw:mrgreen
Back link support
The frame is made in Delrin of 7mm.
Weight : 2.840kg (6.2 lbs) RTR - 1.620kg (3.55 lbs) in front and 1.220kg (2.65lbs) in rear.
Clearance under the frame 7cm (2.75") in front and 8cm (3.15") in rear.
To come :
A small video of the first run :
http://www.youtube.com/watch?v=XdDBRxWVUc4
t the end of the video one sees a little torque twist, but I did not notice it during the use.
The idea is strange, absurd, but that functions rather well :twisted::twisted:
BTA
Back link support
To come :
- Dual ESC Tekin with 45T motor.
- Axial Racing Straight Axle.
