DX6i mixing and expo set up for MOA
souler
italy
Hi there,
I'm running 2 tekin fxr on my berg and already mixed alie and rud for a progressive mix for DIG front and rear.
The problem is to have the front motor start perfectly with the rear 1, when i crawling i always have the rear start in late and have to adjust the trottle with the stick but it is really hard and would like to know if you can help me or i just have to buy a 4pk
Also would like to reduce the neutral run if it's possible for a more accurate control of my berg
tnx
andrea
ps: sorry for bad writing but i'm not american :roll:
There is always clod stall but, Make sure the radio channels and escs are set the same (trim/epa/expo/neutral width). Ya may need to recalibrate the escs together at the same time. Your gear mesh could also be off. Driveline binding? Motors mismatched? There is no reson to go to a 4pk. You actually have more control with sticks.
tnx m8, gonna make all as soon as i'll have time "thumbsup"
Ok all is been resetted but it's still be differences from front and rear motor........front 1 still start running before the rear 1 when the berg is on vertical.......i'm working on the expo but i'm not so good at this work......
If some1 can help me is really welcome:cry:
The front is almost always gonna start first on a steep slope. Thats the stall everyone talks about with MOA. Thats what thru me off the longest after running a shafty so long!!
I run a DX7 on my super. The only way i could get mt rear to start first on a steep vertical was to run one esc per stick. Its hard to get used to but the control is amazing.
