It's red when I turn the pk on to the display on, but when I turn it on to the on side it links up, that may be what I was doin wrong "duh", but when it is all linked up I have throttle and steering but the rear goes forward and the front goes in reverse, and in forward I stops going as soon as I let off the gas, but in reverse it slowly rolls to a stop.
Are you sure that both ESCs are programmed identically? Swap your wires on the rear motor to get it to spin in the correct direction, I assume that you're not running any timing in the motors.
