VP zero Ackerman or high clearance knuckles
cliffhanger007
Vancouver,Canada
Hi i'm looking to get new knuckles and wondering which one is better VP zero Ackerman or high clearance knuckle? Any why can anyone explain the difference? Thanks a lot
There both high clearence, but the 0 ackerman is desinged so both sides are turning the same as where the regular HC arms the inside tire turns slightly sharper.
If you plan on running BTA get the standard high clearance knuckles, unless you get KC Jones' bta link which is designed for zero ackerman knuckles. The VP zero ackerman knuckles and a traditional bta link with yield a lot of toe out. KC's bta is designed for zero ackerman.
Or do as I am currently doing, and make your own link. Fairly easy, just finished my proto last night.
edit...going with the Zero ackermans
thanks for all input i went with LD Racing AX10 BTA Steering Kit for VP High Steer Knuckles (NEW!) and will be getting VP high clearence knukles."thumbsup"
Let us know how those work.....I went with the original LD's and stock Knuk's and always seem to have had alot of toe out. I like the four link plate that comes with it though.
