0lllllll0, I bet you didn't realize what you were getting into by asking your original question.
Well, I did some more research and found the following:
- The stock bottom link ETE is 130mm (106mm post and two 12mm rod ends)
- The top link in the pics earlier were 133mm (106mm post, one 12mm rod end, and one 15mm horizontally curved rod end)
- The TR plastic lower link I had as the top link originally is 122mm ETE (which gave the -11mm difference I supported in earlier threads, but have since abandoned)
After trial fittings tonight, I have concluded (and agree with Black Venom) that 98mm posts with the 15mm horizontally curved rod end and 12mm strait rod end would work best. This link ETE would be 125mm. I think it would put my rear pinion angle the same as my front.
I know I have had fun with this discussion and maybe it helps someone. 0lllllll0, keep in mind that even though we all have the SCX-10, we can have different set-ups and use different parts. That is one thing (of many) that makes this hobby fun.
2500hdon37s, Thanks for all your help also.
