4PK case works great and is great quality. If you want something a little cheaper just about anything made for a 3R works well too.
Too long to read, sorry if this was asked before
Is there a way to set it so on the main screen you can see a percentage of the mixing?
Nope, but you can do this:
Menu -> Advanced -> Dual ESC
Then just drive from that menu. It shows you if you're in dig and what percentage the ESC's are at. That's how I drive with mine.
I want to setup where I can have 4wd, freewheel and locked for the dig servo. I've read through the manual a couple of times and have tried some "solutions" but nothing has worked to this point. Can you give a walkthrough Harley?
hey man no worries, that seems like an easy setup that I could even follow :ror:
I appreciate the help/time that you have taken with this thread"thumbsup"
Holy hell...information overload by page 36.
My main question is:
If I'm going to run rear steer on a scaler, is there a thumbwheel like the 4pk to roll from side to side? Also, can you set it up to auto center with the push of a button?
Thanks, Tim.
Thanks again for the easy instructions.
Zack
Ok, scaler application.....Running 4WS on channels 1 and 3. Works well...My winch is on channel 4 activated on DT2 at 100% forward and reverse with a pause in the middle. Still good. The problem is when I run my winch, it also moves the rear steer on channel 3....I searched the menu 4 times with no luck as to why this happens...Any ideas on what is wrong with my setup?
Check the PMIX menu and make sure it is not mixing channel 3 and 4.
Oh crap! Wrong thread....Got a 4PKS...Same solution?
