so whats the major difference between the 4pk and 4pks? Im on the hunt for a 4pk but i just noticed there was a difference and yes i searched before asking.
ive got a 4PL question. maybe i didnt see it when i skimmed this thread, but what battery are people using. i here life is really good but my lhs doesnt have any that would fit the 4pl. thanks.
It doesn't matter where you put the BEC actually. So you are good to go.
Okay, so far so good. I programmed the 4PL per your video -- but a question: The video said to put the dig on CH4, but your wiring diagram shows rear ESC plugged into CH3 on the RX. I confuse easily...but I'm new at this.
Should the rear ESC be plugged into RX port 4 instead of 3? Or is this another one of those things that doesn't matter?
Edit -- Oh, wait. There are two versions of your diagram. I have one where the RX is marked 1,2,3,4B. Your current one is 1,2,4 & Batt. My RX is 1,2,3,4,5,6B. I'm using 1 for servo, 2 and 3 for the ESC's and 4 for the BEC.
Edit -- Oh, wait. There are two versions of your diagram. I have one where the RX is marked 1,2,3,4B. Your current one is 1,2,4 & Batt. My RX is 1,2,3,4,5,6B. I'm using 1 for servo, 2 and 3 for the ESC's and 4 for the BEC. 5 & 6 empty. That okay?
There is only one 4PL version. No idea where you are seeing more then one unless you are looking at a 4PK version.
Just wire it like I have shown. BEC position doesn't matter.
Yeah, all I have is a hard copy I printed out a while ago. Don't remember where I got it. Nearly identical to your current -- has your name lower right, but no image of the 4PL in the other corner. Besides the different RX labels, the only difference is all the wires have square corners instead of chamfered corners. No matter...I'll trash it and use the current one.
But my question was if I need to put rear ESC into RX CH4 since the TX was programmed for dig on CH4. Your diagram shows it in CH4, but your RX has no CH3 and mine does. I am trying to follow your diagram, but your RX doesn't match mine.
hey Wam if you come out to our comp on sat. just ask for me and you can look at my set up ive been running the 4PL for a while now
The worst you will do is have something not work correctly if items are plugged into the wrong port on the RX.Hopefully you can't hurt anything by plugging into the RX wrong.
I just didn't put CH3 on there because it isn't used. It's just a graphical representation.
Understand -- thanks. PM sent.
Is there anyway to program prooportional dig to the front and back?
I can get it to work for the rear but not both ends.
DT4 is used for dig mix CH4, rate at 100.
DT3 would be set ESC rate but this only work proportional rate to the rear.
Cheers
Rudolf
Finally broke down and ordered a 4PL for my E-maxx test-project truck
would like to set it up this way
Ch 1 and 2 steering and throttle
Ch 3, rear steer, switchable mixing, 3 position switch (right-neutral-left)
Ch 4, transmission, 2 position switch, low-high
any setup examples, or tips for me to ponder while waiting
for my UPS lady to show up
Thanks
