GT3B Hack Question and Answer Thread
looks like ill be picking a few of these...
i was wondering how well they work.
Very comfortable to handle, I put a 2S lipo in mine, deans plug...so I can use any battery I have in my stable...well all but the big lipos, and it is really light..I am going to get another one for my wife....the only thing I really don't like is the position of the wheel, I wish it was closer to the face plate, not down and out
Not sure if i can help much on that. BUT
I'm going to be working on a new trigger mechanism and some new buttons for the ch3 trim and d/r switches and the ch 3 button...mostly i'm just going to rais them up so their easier to switch. The buttons will probably be delrin. Trigger may be delrin or aluminum. And i'll be going to a 60/40 setup, instead of keeping the 70/30. Make the finger slot abit smaller, as i've seen complaints about that gap. Usually the fix is some fuel line.
ATTENTION
It turns out i received afew bad programming boards in my last order, I'll be contacting everyone from orders 192 and up that i have shipped a hack kit to. Some have good boards, some are bad. If your computer is telling you a error that the USB device has malfunctioned and/or in stvp that it can't communicate with device, Please email me as soon as possible, my email is losikid@overkillrc.com
Thanks
When I set up my winch on ch3 trim or d/r there is constant power to the winch. Other than that the winch works properly. On the ch3 trim channel the winch slowly unwinds without touching the trim button and on the d/r channel the winch slowly winds. Any thoughts on what I may have overlooked?
Centering/trim on the channel? Can you adjust the neutral width?
I have no clue, I'm just suggesting.
Well, in my case the rear axle is for ch3. When I went to rev menu and chose ch3, the motor started spinning immediately. After I calibrated the esc, this thing has gone. So, may be, this is an issue to be checked.
Thanks to Charlie and losikid.
They call this "drift"
i'd suggest going into the sub trim menu (enter long on trim) and adjust the trim to the channel your using so there is no drift.
Also getting a HeyOK no drift controller will help solve your problem
Ummm, what was your problem again?
When you go to reverse menu and choose chn 3, the axle starts spinning instantly. Fixed with calibration. Also had to turn the reverse on to stop it spinning and calibrate.
Right you were. However The trim was set to 0 when the issue was occurring. I dialed it down to -35 to make it legit.
That appears to only have been a temporary fix. The next time I turned the radio on I had to dial it down even further before it stopped winding. Anyone else familiar with this?
Had this same issue with the stock controller. Went to a speed controller to control the winch, and haven't had an issue since. Just seems to be something with those stock controllers 'cause it happened with my spektrum controller as well.
An ESC to feed you winch is the ultimate if you have the room and a good way to control it. If not, I have you covered with one of these:
Winch Controller for Radio with Three Position Channel
Winch Controller for Radio with 2 Position Third Channel
Higher Voltage Winch Controller
I just got a new order of programmers in. The packaging has changed abit, so i'll make sure the board hasn't changed and my instructions are still valid
It will take me a day or two to get caught up on all orders past due (because of this faulty programmer dilemma )
Thanks for everyone's understanding on this situation
im intrested in this radio...
but ive heard theres a glitch when next to a spektrum radio?
i have the word from good source..there were 4 of the fly skys
and the rest mainly spektrum..when the rigs with flysky equip rolled up close to rigs with spektrum equip,the spektrum rigs started shaking and glitching..?
has anyone else noticed it?
ive heard theyve banned them from on-road racetracks as well.
im not dissing the radio, just checking out all rumors before i buy.
Yea, a spektrum rig might experience some glitching. The AFHDS is defiantly a brute when it comes to sharing a frequency band. I know when my radio is turned on, my wifi spots quit working, so does the 2.4ghz house:roll: Oh and netflix:roll:
But, at the same time why does spektrums high dollar system cripple by a pretty cheap system. Just proves how secure their signal really is.
yea, a spektrum rig might experience some glitching. The afhds is defiantly a brute when it comes to sharing a frequency band. I know when my radio is turned on, my wifi spots quit working, so does the 2.4ghz house:roll: Oh and netflix:roll:
truth!
