Here is the issue. I have a dual fxr set up (using CC bec) and use a hacked
gt3b radio. One fxr is quite new and never glitched before. The second i got from a rccrawler fellow, used, but still claimed as ok one and i trust that guy.
Rig XR10
all wired up and soldered correctly.
1. When i turn on the radio and esc see it, the rear wheels do a one round spin back and then stop. I can drive after that "normally" but!
2. Once you pull the trigger softly front axle goes first and you need to pull a bit more for rear to start rolling.
3. Rear wheels spin slower than the front. Pinions are stock.
4. Today the rig became unexpectedly out of control, once. It started going forward at full throttle. Was hardly caught and cut the power.
5. I can't calibrate the esc with radio. I mean it work, but if i do want to calibrate esc with radio, then, when i pull full throtle nothing happens.
What is wrong?
Thanks
Boggie
Rig XR10
What is wrong?
Thanks
Boggie
