KC's commemorative build (ACTION PICS!)
Re: KC's commemorative build
Input...I love the paintjob! but...is there any way you could integrate a rotor graffic somewhere in there? On the hood? On top of the cab? I've been staring at this for half an hour and I can't think of how to do it. That's my only thought. Maybe this on the hood? Just a thought...
Lol on the nose of the A/C there is the a/c number and our squadron logo so that will go there. Maybe somethin on the roof. But don't wanna ?over? Do it...
Here's a shot of the nose.
rear axle and susp is done.
first order of buisness.
remove rear axle
next gather new parts for axle
open axle case and see whats inside
i removed old ring and pinion gear and swapped to hardened underdrives. finished it off with red grease
put axle casings back together and install new goodies axial lockouts and r2j 4link truss
all installed ready to go
decided to utilize touring car shocks in the rear. and for the upper links i just used same method as described b4
NEXT ON THE LIST TRANNY/DRIVELINE
trans/drivline
first up remove stock trans as required.
once your trans is removed gather up parts planned for install. rr hardened gears steel outputs mips hh 35t
next up open trans case to expose stock gears
utilizing the old hardware assemble new gear with new outputs
remove stock idler gear and swap bearings and shaft to new hardened gear. coat in grease to keep in smooth and put both gear sets back in
close the case up and wipe exess grease and install motor
all finished up w/ mips. make sure to loctite all setscrews.
next up front axle
coat in grease and reinstall
lookin good man, its a shame you wont be able to make the g6 event. but thanks for your service!! trucks lookin good so far, looks to be a pretty stout little toyota!!
ok update and im officially done for today. lol
removed front axle as required
i dissasembled the axle and began prepping the casings to fit the beef tubes
didn feel like taking pics of the build up but its pretty self explanitory. added beef tubes, axial chubs, vp knucks, axial cvd's, gcm truss for upper link mount.
also traded NJK for some C1 baja claws. i weighted the fronts 3 oz each and rears 2oz each also vented the rims
Awesome build pics as usual. I like the squadron logo. That should definitely go on the hood! And a small "don't tread on me" serpent on the back window. You don't necessarily need the text. But a black graphic. I think that would be killer as well. Just the imagery is nice and would balance out the graffic on the hood if you go that direction. Don't feel pressured by my suggestions...It's easier working on your build than it is on mine!!!!:lmao:
thx man! ill def be lookin into the graghic. that would look awesome.
Tires fit cherry!
thx they fit perfect in the wells.
i know i said i was done earlier but i couldn stop.. lol its an addiction the only way to cope with it is feed it!!
well its a full roller got the home brew cms and 3link with panhard finished. its a little dark so sorry bout the pics.
also switched to an internally sprung axial shock. running about a 50/50 droop. utilizing bump stops to keep the tires out of the fenders.
i took the short upper soft springs from the stock shocks and transfered them to the rear touring car shocks to make them a bit softer.
after all this i was still able to maintain a good ride height.
i still have all the old components so if i wanna switch back to a full sprung front i can. ill just have to do some testing to see what works better with this rig.
"thumbsup" Looks like some tight quarters in the clearance dept. Interested to see how the test run goes!
