Wreckluse
Cool deal on the housing and dig Just. I have those myself along with their axle housings, and the machining and finish on them is excellent. I'm building a SCX10 based Cherokee right now for my helper (wife) I thought about putting the dig in the wreckluse, but decided to leave it out so I can compete if I want. I went with the mini servo mount and a Hitec 545BB servo for the dig, what servo do you plan on running on yours? It will be interesting to see how you end up mounting your servo in the wreckluse. When I was eyeing it out for use on mine, the only way I could see to get the dig servo mounted would be to weld a plate in the rear chassis section, mount it there and run a long link. Even with my mini servo bracket installed on the dig itself, it still hit the cross members in the wreck, so the plate in the rear seemed the easiest solution.
C
havent thought about the mounting part yet. i have to see it then go from their.
sweet rig it looks to sexy to scratch up.hehehe lucky man you spouse drives to. i wish mine would. but my two year old loves to so i guess i am just as lucky
There is a pic somewhere round here of a wreck with a vp dig on it, Ill see if I can find it. Yeah wifes into it a bit, but her driving skills probably on par with your 2 year old :lmao: :roll:
@ Modbug, yeah I've got build up pics, will be starting thread in a day or so.
Hi i found some light buckets for my grill neds a little moding tho. A minimag light reflecctor thingy. Going to glue itin from the back.
Dose any one know what type of glue to use on the lense ?
I know ca will cause it to turn white any ideas please
Light bucket mod completed. A friend had a broken mini mag to so i didnt have to buy one to part out. The lights are 5mm LEDs so just had to drill the housings out to hold the LEDs in.
Not sure what pics you're asking for.
I have a Timberwolf chassis, that's why I'm checking the Twolf and Kluse threads.
Bought used, but don't have any plans for it yet.
You can ship it to me. I am sure I could find a use for it! :lmao:
No, not built, in pieces right now. Bought used, front stinger was broken.
If I build it I will change the stinger and some other cage bars. I have some aluminum standing by.:)
Postclanker some thing coming your way.
Cloudswimer hows your build coming.
Just got the dig unit fitted now i have to work on shafts and other misc stuff and got an 1/8 scale winch after its all built and bugs worked out going to have to take it appart and have some plates welded in the back and the front .front plate will be high so the stering servo will clear the winch not real pretty but functional.
