No, iam not sure if it is the servo or the radio, so i think i will put my new radio in the scaler "thumbsup"Rocky, did you get your servo issures resolved?
I have a new servo to, so i will probably put that in it too :ror:That's a good start. "thumbsup"
Dont need no stinkin BEC. Just make sure that your servo full travel stops at the same time the mechanical linkage do.Sweet between the both you should get it, if your running a bec what is it set at?
I just dissected a 24 volt cordless drill. I has a 750 brushed motor in it. So does that mean I could throw 24volts of lipo bliss at that bad boy? Quick I need something to try it it. How bout one of those juggernauts icky?
You stay away from my jugs.:lmao:
Why the change of heart. Is it because we aren't alone right now?:lmao::lmao:
Hmm, I Dont use a BEC and am running A few of the LARGEST HIGH TORQUE servos on the market.:roll:Sure if your running baby servo's:twisted:
Savox SA-1230SG 500oz in Wratingo
Savox SA-1283SG 416oz in Wraith-19 VP White Comanche
Hi-Tec 7955TG 333oz in Wraith 1
Running 2S, if I was running 3s then I would install a BECAre you running 2s or 3s? From what I read in the wraith forum it isn't a problem unless you go 3s, then the servo ends up browning out for some reason.
getting ready for the g6 what do you guys think??
