Menifee-Temecula area crawlers
Did you read all this?
STOCK# - TAMC8496 MFG# - 58496 New and unused. In the original manufacturer packaging.
This ships FREE within the U.S. when using ground service. If ordering it
you may add more items to your order without incurring any shipping charges
if shipped within the U.S. using ground service.
This is the electric powered radio controlled 1/10 scale
Fast Attack Off Road Vehicle Kit from Tamiya.
FEATURES: Chassis: Bathtub style ABS resin plastic construction
Drive: Rear wheel
Motor: Johnson/Mabuchi 540-J size brushed
Pinion Gear: 15 tooth
Electronic Speed Control: Tamiya TEU-104BK with reverse
Body: Resin molded in tan
Gearbox: Enclosed
Differential: Bevel gear type
Suspension: Front and rear trailing arm with front coil springs and
rear shocks
Wheels: Three piece front and rear
Tires: Treaded rubber off-road
Caster: Non-adjustable caster/toe-in refers to the angle of the
front suspension when viewed from the side of the car in relation
to the chassis
Camber: Non-adjustable camber refers to the angle of the tops of
the tires from vertical when viewed from front or behind vehicle
INCLUDES: Fast Attack Off Road Vehicle Kit 540 Motor ESC 15T Pinion Gear
Helmeted Driver Figure Decal Sheet Tires Wheels and Instructions
REQUIRES: Radio: Two-channel with standard servo for steering
AA Batteries: Eight for transmitter
Battery: 7.2V 6-cell stick pack with standard connector
Battery Charger: Peak type recommended
Paint tools and track equipment
SPECS: Length: 16.9 (430mm)
Width: 8.7 (220mm)
Height: 5.9 (150mm)
Weight: 2.64lbs (1200g)
COMMENTS: To upgrade to ball bearings use;
Qty. Size Location Qty. Bearing Set
1 5x11mm Spur Gear 1 DTXC1547
1 5x8mm Gearbox 1 DTXC1523
2 5x11mm Rear Axles 1 DTXC1547
4 5x11mm Front Hubs 2 DTXC1547
2 5x11mm Rear Hubs 1 DTXC1547
jxs 08/08/11
ir/jxs
Purchasers of this product also bought:
Duratrax Bearing 5x8mm (2)
Duratrax Bearing 5x11mm (2)
Futaba 2PH 2-Channel AM/1 S3003 Servo
Tower Hobbies 224 2-Channel 2.4GHz Radio System
Futaba 2DR 2-Channel AM/2 S3003 Servos
Tamiya Super Hotshot
Ickabob,
I read it all and I am looking at the FAV in the box here in the living room. It was delivered yesterday by either UPS or FedEx. I don't remember which one. It was in the yard when I got home after getting one new tire for the 1:1 Ford truck 6 more tires to go.
Does anyone have any idea what the degree/angle the rock is in the picture posted on this page? I have to add more weights to my LMRC in order to for it to make it to the top. Thanks.
Ickabob,
How are you feeling this evening?
What did I do or say that there are only three of us on this page?
I would think your LNC 1/10 has a better chance of making it cause that rock is strait verticle in some areas. But then I don't know much bout Losi crawlers so. What do I know..:lmao:
Swagganaut,
The machinegun is an M-60 7.62mm round belt fed, gas operated fired from the open bolt position. When it didn't work it was a 23 pound club. I was an assistant machinegunner for the Security Elements for Contingencies (SPECS). As an A1C (Airman First Class) I basically lived with that weapon for a week or was it two weeks, at the Small Arms Range at Nellis AFB, NV. Every 5th round was a tracer.
Swagganaut,
I need one of those M-60 for my scaler.:ror:
Swagganaut,
It appears that the machine gun is a combination of the M-60 and the 50 cal machine gun known as the Ma Duece. The part # D Parts x (1) parts tree 19000238 (D1) (D7) BC2 (2) BC14 (1); BC14 x (1) Spring. (2) 3 x 6 mm screw. If that helps. Also take a look at the instruction manual on Competition X for either the Fast Attack Vehicle (2011) or the Shark Mouth Fast Attack Vehicle, you can also go to the Tamiya site look under instruction manuals.
To TVC members,
Would the FAV be classified as a scaler since it is based on the Chenowth military buggy? Does it have to be 4wd?
Swagganaut,
I forgot to add a few more part numbers.
Spring (BC 14) x 1 P/N 15040013
Screw (BC 4) x 2 3 x 6mm P/N 19805636
Screw (BC 1) x 1 5 x 10mm P/N 19804491
D Parts Tree P/N 19000238
I hope this will help.
