Wraith Electronics box
If you need to punch out the battery tray, use a heat gun and press the box dimensions out using a hard case lipo. (Do NOT apply heat with the battery in the tray. Heat, then press.)
Can't wait to get the rear box and cover so I can lay out electronics. 2.2 pitbulls are on the way. ImageUploadedByTapatalk1359241854.540836.jpg
I want one of these, added my info to the list.
Name/Screen name/Item(s) you want ie; front box, rear drop box with or without flat cover.
1.robert chinchilla/ robchinchilla.
Order sent 1/17
2.rhett cale dieselmudder front electronics box.
Rear box w/ cover.
3.Chris / Baja Bandido for rear drop and cover
4.brian pratt/madtinner rear drop and cover
5.
Blayne Brock/ Devil Inc - front electronics box
6.
7.
8.
9.
10.
Alrighty gang, we're going to augment the waiting list so theres no confusion when we PM everyone for availability and fill orders "thumbsup"
Please copy and paste this list when you add your name to the list so we can keep track of everyone. We get ALOT of PM's to plow thru each day on top of running the shop and this will keep everything in line, thank you guys for your understanding "thumbsup"
Seems pretty simple to me...
1.robert chinchilla/ robchinchilla. Order sent 1/17
Rear box w/ cover.
5.
6. gbean. rear tray with cover.
7.
8.
9.
10.
I'm aware how that works, I already have the electronics box.
I was under the impression the rear covers have yet to be produced...
Also, crawl space-i just want the cover, not the box.
Awesome products guys! I'm going to keep an eye on this because I'd love to know what things look like when the rear is officially released. I'd probably be in for a front, rear, and cover (but don't put me down yet - I want to see what pricing is first).
As promised here is how I heat molded my box to make hard case lipo batteries fit - just get a heat gun on the outside of the lower corners on low setting. As soon as it gets pliable press a hard case Lipo into the corner then run cold water over the abs plastic to set the mold in place. Worked great! Just be sure to keep water off your battery.
Also be careful when trimming the abs - it tears much easier than lexan..
2.rhett cale dieselmudder front electronics box. Rear box w/ cover.
5.Blayne Brock/ Devil Inc - front electronics box
7.zero1- front elect box
8.
9.
10.
Got mine and fitted it today. A word of caution some of the corners get pretty thin from the mold. I ripped mine some when I drilled the holes to put the cross brace through. Other than that very pleased. Lookin forward to getting the rear.
Edited:
6. gbean. rear cover only, no tray.
8.
9.
10.
Thanks for posting up examples "thumbsup"
Best to use a lexan body reamer or xacto for holes in the ABS, it won't tear and its alot easy to control than a drill
I used a reamer and lexan scissors. That worked well, however the issue is that the box is too thin in some spots.
