IT'S ALIVE!!! 2 nights ago I spent all night working on the rig and got it half alive 5 in the morning and running the next day. Although it's no where near done, it drives though, finally got to drive this thing on my living room floor after 3 months of owning it. All I can say about this Tekin ROC 412 motor is WOW it is so buttery smooth very impressed with it.
Anyways, here's my UPDATE. Again guys the comments and feedback are awesome, I really appreaciate it!
Let start off with the next Box, I used a Traxxas Slash 2wd RX box to house the follow items: Tekin FXR, Tekin B1R, and a Castle BEC. I know it's not super pretty because this was a really tough one to pull off. The box had 2 holes on the bottom of them so they had to be sealed which I did with some counter sunk screws and locknuts. With those screws in the way they interfered with how the items were organized in the box. Anyways here it all is!
One of the tough point on this was that I want to use one battery for all electronics and this box would be the hub where all power go through and there had to be another set of wires where this would connect to the Tekin RS in the back.
Now! next was to seal my last piece of electronic which is the Airtronics Receiver which I used a Traxxas Stampede RX box but I want to make it water proof but still able to connect and disconnect the ESC, servo, bec, etc with out having to open the box. So I got a bunch of servo lead extensions to extend the plugs to be outside of the box.
I started with a clean way to roll the RX antenna the coaxial wire is really annoying to use because it doesn't seem to ever want to go where I want it to go so I used a nut and cap head screw to roll the coaxial wire around and wrapped it in shrink tubing, I know you guys are all going WTF!!! what about reception of the radio but I have done this because and it worked fine.
I scribed in the lead connectors to know exactly what each wire is for.
Finally done 4 rx wires and the other two are sensor wires for the telementry : Temp Sensor for Motor, and RPM sensor which will be for speed sensor.
Finally I installed the two boxes. Shortened or lengthened and leads or wires. I also tried my best to make it all clean. What do you guys think???
Lastly for this update I installed with I believe is the best 1/10 scale servo that could be used on a Scale Crawler at the moment a Futaba BLS172HV aka Futaba BLS157HV.
Specs: High Voltage 2s Lipo Compatible, Speed 0.11 sec/60° at 7.4V and Torque 513.9oz/in (37.0kg/cm) at 7.4V very impressive specs
Coupled with a Clamping Aluminum Servo Horn. Futaba splines are 25 incase anyone wants to know
That's it for this update, it was a lot of work but I think it was all worth it, one of my pride is wiring something neatly and cleanly, again Let me know what you guys thinks. AND stay tuned for the next update.
