As most of you may know I purchased chino63s 83 Hilux, and while I am extremely happy with the truck overall (it's what I have always wanted) it is extremely slooooooow :|. I spoke with Dean in depth about this yesterday and I was explaining to him how I don't understand why it feels so under powered compared to my 86 4runner which also had 35s/4.88. He then reminded me of the fact that the truck is a California spec model and that the California spec trucks actually came with a slightly smaller cam shaft to help with the tight smog regulations based out of California...
So with that said I have spent the better parts of yesterday and today researching how I can make the truck move a long a little bit better. I am posting this hear becuase I don't wanna deal with the BS on pirate and I have searched already I am just looking for some 1st hand experiences as I know there are quite a few members who have been probably wheeling toyotas since I was shitting in diapers :lmao:
For starters, I am not doing a 3rz swap or 2.7 or adding a turbo or super charger or anything like that...those are all out of the question.
5:13s/5:29s also out of the question, I cannot set gears myself (wasn't taught in all the schooling I had and toyota just replaced 3rd members ) and I have seen to many broken ring gears as well.
Truck already has an LCE header on it as well.
I am also emissions exempt as well, so I don't have to worry about that.
So far, my ideas are this...
Weber 32/36 carb and matched down draft dual plane intake manifold and fuel pressure regulator upgrade: truck has the factory asin carb and while the truck runs mint now (especially after a fresh tune up) the research I have done shows this carb is suppose to eliminate all the emissions BS, improve idle and over all drivability plus has support for jetting and easier rebuilding/servicing, allows for a more free flowing air intake as well.
Cam shaft: This seems to be the most effective upgrade that i have read about. Only downside is that the rocker assembly is held down by the head bolts :x truck is technically do for a timing chain set since its got 105k on it. While its not rattling at all I think it would be good to step up to a nice dual row chain. In my experience with these it's almost easier to for me to pop the head up off to do it so I don't run the risk of damaging the part of the head gasket that hangs over the timing chain cover. Since i worked for Toyota for years and Having rebuilt my 22re (twice actually) I can dissemble the motors with ease so the head gasket job doesnt have me worried. Considering eithers Engbldrs Cam or LCEs. Found a Dyno chart on pirate and these 2 had the best numbers.
Performance distributors DUI distributor: 100% water proof, eliminates expensive igniter that's prone to failing, stronger spark will burn fuel better etc
Electric fan: supposedly reduces the drag of the stock clutch fan and from what I have read is suppose to make a decent difference.
Other ideas, install test pipe in place of catalytic converter, free flowing muffler
I understand this motor is never gonna make crazy power, I'm not looking for that. I honestly like the fact that they aren't overkill as I never broke any axle components being on 35s locked/locked in my 4runner running black/red trails at Rausch Creek. I am just looking to not have to drop it from 5th to 4th for the slightest grade in the road.
Anyone who has 1st hand experience please chime in, if you read it in the Internet I don't need your help, I need guys who actually have had these rigs and daily drove them to and from the trail with similar set ups.
Truck has a doubler and 4.7:1 kit as well so I am not worried about loosing a little bit of low end torque, the reductions Will make up for that on the trail.
I am looking to improve the 2200-3000rpm range which is what the typical range is for road use.
Thanks
Mike
Thanks
Mike
