Kratos
While "The Thing" has served me well it was time to move onto a new chassis. Don(BWD) and I have been talking for a while about a new chassis and he told me he had something in the works. I got my chassis last Friday but was unable to get it ready for my comp Saturday because I didn't have any body mounts. This will be a bodied rig and Im very excited about that. I asked Harvo where he got his body mounts for his sporty and he pointed me to Gunnar mounts. Thanks! So I hit him up and ordered me a set of them. These mounts are sweet! I used the same electronics that were in my other truck. Im not happy with the way I have them and will most likely be ordering some Holmes Hobbies BRSL's. Now I did order some motors from Mr. Holmes and they are gonna be sweet. They are the 30t Team Pro Flow Crawler 540 Motors with ceramic bearings and stage 4 weight kit. I cannot wait to get these bad boys and run the you know what outta them. So Ill give you folks the low down on electronics and setup for now
Chassis
BWD "Nightmare" with BWD Ti lower and upper links
Electronics
Mamba Micro Pros(x2)
CC Bec set at 7.6v
Futaba BLS157HV servo
30t HH hw motors with 14t pinions
Futaba 4pk
Front Axle
Vp top half
Vp chubs and XR knuckles
Vp upper link mount
Vp tranny case and motor plate
Vp XR-10 VVD axles
RC4WD gears
Dlux Knuckle weights
Dlux no slop knuckle bushing
Rear Axle
Vp top half
Vp upper link mount
RC4WD gears
Stock lockouts
Tire/Wheel setup
Front: Wheels- Vp DHII with Voodoo tires (compound will vary with terrain)
Foams- CI DD 5.5 narrow inner with medium outer
Rear: Wheels- BWD CF Mod-Locks with Voodoo tires (compound will vary with terrain)
Foams- CI DD 5.25 narrow inner with medium or firm outer and a medium tuning ring
Ive put about 15 packs through this truck and at first I was having a heck of a time tuning it. It needs an entirely different tune than "The Thing" did. I talked with Don about where to start and that helped a ton. I went through 10-15 different shock/oil setups and finally found one Im starting to like. Im using 4in big bores limited 1/4in internally with silver springs in back and red springs up front. Both shocks have 80wt oil in them and that has helped a lot as well. This truck is a breakover monster! It does breakovers and launches verts much much better than my thing ever did. All I have left to tune is sidehilling since its not quite as good as the thing was for me. Stay tuned"thumbsup"
Chassis
Electronics
CC Bec set at 7.6v
Futaba 4pk
Front Axle
Vp top half
Vp upper link mount
Vp XR-10 VVD axles
RC4WD gears
Rear Axle
Vp top half
Vp upper link mount
RC4WD gears
Stock lockouts
Tire/Wheel setup
