As I promised a long time ago here is a current to date Parts/Price list of this current project.
I hope this could help anyone wondering what part is what on this rig. I will add to this list if there are any changes. I arranged the parts into sections for an idea of total amounts.
Electronics:
Tekin Roc 412 3100kv = $149.99
Tekin RS ESC = $174.99
Tekin FXR ESC = $99.99
Tekin B1R ESC = $59.99
Castle Creation BEC = $24.99
Futaba BLS172hv = $219.99
Airtronics MT-4 = $229.99
(6) Thunder Power G6 Lipo 3s 2250mah 65c TP2250-3SPP65 = $59.99 each
Total = $1019.92
Winch
Quick Sand Warn 8274 Winch = $225.00
Winch Line = $5.00
Total = $300.00
Wiring:
Shrink tubing for everything = $15.00
Deans Connectors (2 sets of ultra plugs, 1 4pin Micro, 3 2pin Micro) = $15.00
(2) 3.5mm Gold Bullet Connectors - EFLYRH3 = $5.98
(5) JR Sport Servo Extensions = $14.95
Y-Harness EFLRYH3 = $3.99
Total = $54.92
Lights/Body:
VP Rigid 6” Silver Light Bar LED VPS06752 = $59.95
VP Rigid 5” Silver Light Bar LED VPS06754 = $57.45
VP JK Light Bar Mount Silver VPS06781 = $26.25
Exo Rear Light Bezel AX80103 = $11.99
Dinky R/C JK Headlight n Tail Light Kit = $20.79
GT Power RC LED Light Kit = $23.99
Custom Headlights Setup = $100.00
Pull Pal RW-60 = $24.99
Mad Skinz Jeep Wrangler JK Soft Top = $19.99
Total = $345.40
Drivetrain:
(2) Molded Drive Shaft VTR232021 = $14.98
(4) Driveshaft Yoke, Cup, & Hardware = $39.96
Hot Racing Silicon O-Ring RTD372 = $2.00
VP AX10 Transmission Housing Grey VPS01188 = $46.99
VP Incision Gear Guard Black VPS02200 = $29.00
Robinson Racing Hardened Steel Idler Gear RRP1541 = $12.75
Robinson Racing Hardened Steel 1-Piece Outdrive RRP1542 = $25.49
Robinson Racing Hardened Steel Pinion Gear 18t RRP1418 = $3.99
3racing AX10-02/GR = $10.00
Kimbrough 84t 48 Pitch = $5.00
Total = $190.16
Chassis:
Axial SCX10 2012 Jeep JK RTR = $379.99
VP Incision Hoops Front Raw VPS01857 = $22.99
VP Incision Hoops Rear Raw VPS01858 = $22.99
VP Titanium 10 Piece Link Kit Currie Axle VPS06732 = $89.99
(4) VP Titanium 4mm x 110mm x ¼ Link VPS03831 = $32.60
(2) Pro-Line PowerStroke Scaler Shocks PRO6060-00 = $89.98
Jeepindoug Scaler Shock Machined Delrin Spring Cup = $12.95
RC Screwz SCX10 Screw Set RCZAXI002 = $29.95
Axial Post 7x70mm AXIA1431 = $7.79
Axial Post 7x10mm AXIA1419 = $4.89
Traxxas Slash 2wd RX box TRA5624 = $12.99
Traxxas Stampede 2wd RX box TRA3628 = $12.99
Traxxas E-Maxx RX box TRA3924 = $12.99
Integy Futaba Aluminum Servo Horn C22944GUN = $11.99
RC Rock Armor SCX10 Shield Quick Sand Winch Bumper = $69.99
RC Rock Armor SCX10 Rear Bumper w/LED Holes = $34.99
RCBros Servo Clamp = $3.89
Total = $853.95
Wheels/Tires:
(3) VP 1.9 Scaler Screw Kit = $35.97
(2) VP SLW 600 Wheel Hubs = $29.98
(1) VP SLW 475 Wheel Hubs = $14.99
(5) VP OMF Scallop Bead Lock Ring Grey = $52.50
(5) VP Front Ring Black = $52.35
(5) VP Clamp Ring = $20.00
(5) VP Outlaw II Rear Ring Gunmetal = $65.00
Crawler Innovation Lil Nova 1.9 Dual Stage 4.5T MED Foam Pair = $10.95
Crawler Innovation Lil Nova 1.9 Dual Stage 4.5T FIRM Foam Pair = $10.95
Total = $292.69
Axles:
VP 8 degree Knuckle Weights VPS04000 = $68.99
VP Knuckle Weight Rings ¼ VPS02812 = $20.99
VP AX-10 8 degree Chubs Grey VPS02866 = $42.99
VP AX-10 8 degree Knuckles Grey VPS02856 = $42.99
VP AX-10 VVD Set VPS05321 = $94.99
(2) VP Locker VPS05990 = $67.98
VP Currie Front AX-10 Axle Grey VPS06603 = $169.00
VP Currie Rear AX-10 Axle Grey VPS06604 = $140.50
(2) Axial Heavy Duty Bevel Gear Set 36T/14T AX30401 = $57.00
Hot Racing 12mm Aluminum Hex SLF1006 = $12.99
Total = $718.42
Current Running Total = $3775.46
There are a couple of items I didn't list due to the fact they aren't available.
