chris.martell
Are you planning on running faced wheels?
Rovers with optional sipping
A little something like this... half cut off lugs and half finishes shaved.
Good idea on the knuckle bushings.
Front axle is coming along nicely.
Good work.
By faced wheels I meant a wheel that the hub bolts to the face of the wheel. It helps get your track width narrower than 11in. It does require a slw hub or some sort of hub like them
Not if you have enough caster and dont rush yourself take your time and tweak and tune. But your servo/4 link plate will need to be modified to not rip the tires.
Do you plan on comping this rig or driving it for fun? If you don't plan on going to comps just leave it and have fun driving
If not the Slw hubs, cause you don't know what size to buy..
Check out lattice innovations, Shift hubs.. pm Bc-brian for a set.
I enjoy shaving tires myself.. I cut lugs while I watch tv .. when I have them all ready, I hit the shop to make a mess..![]()
Before you mount those freshly shaved tires, narrow your stock rims.
That will stand the tires up a bit, and narrow the track width for you.
I cut on the back of the beadlock on one side, trimmed out some of the middle, and then CA glued them back together.
Since I cut the one side flush to the back of the beadlock, the screws are long enough to help line the halves up and tie them together.
Never had an issue, and I love them.
Can't remember if I have pictures on my build thread or not.
I have the same wheels you do (kinda....lol).
Almost free.......
