On my Nissan the leaf bushings were a press in sleeve. I removed the hanger bolt to the sleeve, with the chassis resting on a jack, not the axle, and just jacked it up till the spring cleared the hanger, then took the blade off a hack saw, inserted the blade through the sleeve, reinstalled the blade to the saw, then made one cut all the way, or nearly all the way through the sleeve, but not the spring. with the sleeve cut, I took the blade back off, and used a deep well socket almost as big as the sleeve and wailed hell on it till the old sleeve bushing came out. Which was not that hard since I made the relief cut which allowed the sleeve to collapse a little and drive right out. To put the new one in, I just put the new sleeve bushing up to the leaf hanger hole and tapped it back in using the socket so as not to damage the bushing center hole. Then let the jack down, reinstalled the bolt through the hanger, and repeated for the other side. Took maybe 30 to 45 mins, after relocating the hacksaw and a new fresh blade.
