But I like the trail ready wheels that came with the the wraith and I need the hubs to run them.
$30 is expensive?
I think most go with a .350 to .450. Your other option is to get a set of $100 aluminum wheels...
yup, when you can get a set of wraith hexes for 6.00 with free shipping...
He won't need the slw hub if he changes to hexes. What are you seeing to write that statement?
....yes he will because the PSC Wraith wheels come with plastic hubs that accept the axle pin, not a 12mm hex.
The best fix is to replace the plastic hub with a SLW hub and 12mm hexs.
you also need new screws for the slw hubs. the stock ps ones are metric and the vp hubs are not. you can buy stainless screws from vp or just pick some up elsewhere.
and for the record, you will need both the hubs and the hexes.
THANK YOU! "thumbsup"
thats why I said I got different wheels, the trail ready beadlocks are garbage..my stock BFG tires kept pulling out of the beads. so for less money than the SLW vanquish hubs cost, I got a set of hexes AND 4 proline eight shooter wheels and no longer had the issue of the beads pulling out of the wheels...
30.00 for slw VP hubs just to be able to use the garbage stock beadlocks.....or 26.00 for 4 hexes and 4 new proline eight shooter chrome beadlock wheels with metal rings...no brainer in my opinion.. "thumbsup"
