OhioSuperSport
I thought I would share this. Danny with SMC batteries posted this.
I'm making this post to try and help educate everyone about how crazy the Lipo ratings have become and are pretty much useless. I know most of you will appreciate this post and some will think I'm just using this to promote SMC but this is really to open some eyes.
First let me explain the fact that their is no true C rate testing standards. Some factories use mAh retention and others use heat and voltage curve to determine the C rate. Every factory knows the C rate of their cells based on one of these 2 methods of C rate testing.
When I started testing and buying Lipos 8 years ago the C rates were 10 to 20C for car packs. At that time the factories were giving true C rates based on their testing method for C rate. Within a few years C rates doubled but this was just marketing to try and sell more packs and make more money. Now 8 years later it's even crazier with some outrageous C rate claims and mAh has also started to increase on the labels but not on the cells. In my opinion 80% or more of the packs being sold in car market today have a true C rate of 15 to 25C using the heat and voltage curve method for C rate testing. Using the mAh retention you can add 5C. There are some 30C and 35C packs available but these are very rare and cost more to make.
C rate is the amp rate at which the cell/pack can be discharged at. So a 5000-20C can do 100amps. A 7200-20C can do 144 amps and so on. IR(Internal Resistance) is directly related to a cells ability to handle amp loads. So it's not possible for a pack to have higher C rate and higher IR. This means a 7200-20C has to be lower in IR than a 5000-20C. The size of the cell also limits it's mAh or C rate/IR. In car packs with hard cases we're limited by the size of the case. This means if you want to increase mAh you must increase IR or vice versa. A 7200-25C will have higher IR than a 6000-35C. The 7200 will be able to do 180 amps and the 6000 will be able to do 210 amps. Only way the 6000 can provide more amps is to have lower IR.
Now that we know this if true C ratings would exist the consumer/racer would be able to know what pack better suits his needs. Unfortunately this isn't the case so there really is no way for the customer/racer to know. SMC is no different than others as we also use inflated C rates as we have no choice. If we would use true C rates we would be out of business. What we do try and do that is different is make sure that our ratings mean something. For example our 5000-40C will have higher IR than our 5000-50C and so on.
Here is something that I find interesting and frustrating at the same time. Some of our competitors buying the same packs we do offer them with higher ratings. This leads to some customers buying these higher priced packs instead of ours. Here are 2 examples. The 4400-60C shorty which we sell for 29.95 is being offered as a 4600-90C at 44.95 and it's the exact same pack that we offer. The 7200-60C-2S pack we offer for 39.95 is being offered as a 7600-75C for 64.95.
Something else interesting is that a customer who bought one of our 5000-40C-2S packs at 24.95 compared it to a 5450-120C-2S pack at 129.99 and told me that our 40C pack ran longer and faster in the same vehicle and the 120C pack was new to make a fair comparison.
Now that we know C rates are all made up and it's actually getting a bit ridiculous to claim even higher C rates it seems like in the past few years mAh is now what is being inflated. Recently I tested a 7000-1S pack that only put out 6222mAh. I will admit some of our packs also have a bit lower mAh than claimed but this is due to the model being improved to provide lower IR. If you drop the IR the mAh drops.
I hope this post can help some of you not fall for all the BS and hype and don't be surprised if SMC starts releasing higher rated packs to try and keep up as it's very frustrating to under rate our packs and lose sales.
