RCCrackHead
Been there done that, talks nothing about performance or AFHDS vs AFHDS2.
I just hacked mine with a two year old kit. Or I should say my wife did. I was having problems with the links up loading right and asked her to help. I had everything hooked up to my gt3c and computer and went out to the shop, leaving all the directions by the computer. Next thing I know she comes out and says the red light is flashing on the board, you need to do the rest!!!!
So yes it will work.
Just through my order in for a GT3B firmware kit. Then realized I have the GT3C... Will I be able to make it work with some direct soldering or buy using a few header pins I have laying around?
They are the same programming just different headers.
Do you want me to change your order to a gt3c kit?
If you could that would be great. I don't know how difficult it is to ghetto fab up what I'll need to flash it with the B. I have 2 radios to do, this way I'll only have one radio that requires a little extra work. I'll PM you my order number.
Can't PM, the order number is OK-1536
Stoked to unlock these radios and throw some holmes BR minis in the rig![]()
fixed, and I'll include a second gt3c header...
Feel free to pm me your PayPal, appreciated.
I've had my radio for only a month now but it doesn't seem to be working properly to me. I was trying to use the exponential function today however it didn't seem to work properly. It acted more as a trim function rather than exponential. When I adjusted the expo, the vechile would start moving forward without me touching the throttle, or if I adjusted it the other way it would go in reverse as though I were adjusting the sub trim. I don't have this prohlem on my futaba radio. Anyone else have problems with the expo funtion? I wanted to soften my thottle but expo doesn't work.
finally hacked mine. 3ch doesnt work at all. any idea why?
reading is this very long thread. i never Calibrated the radio after I hacked it. going to start there
- Key mapping specific for each model:
> choose menu REV and press ENTER-long
> menu REV will blink
> choose trims (id: 1 2 3 d) or other keys (CH3: C, Back: b, End: E) or
if trim is OFF, then also trim keys (id 1 2 3 d with left/right arrow)
> press ENTER and modify first setting
> press ENTER and modify next setting
steps of settings of trims (1 2 3 and D/R):
- sequence:
function -> buttons -> step -> reverse -> opposite_reset -> previous_val -> rotate
- function: selected function listed at the end of manual
- B buttons:
MO - momentary, hold left/right trim key to get end values,
when nothing pressed, servo is at center
NL - no long keys, long press is the same as short press
AR - autorepeat is on
RS - long press of one of trim keys will reset to
centre/reset value
EN - long press of trim key will set to coresponding end value
- step: select trim step for one trim key press (1, 2, ... 100, 200),
not available when buttons MO or fuction is list of items (multi-position)
is identified by symbol "V"
- RE reverse:
0 - no change
1 - swap left/right trim keys
- OR opposite_reset: not available when buttons MO
0 - no change
1 - when trim key is pressed and value is at opposite
side of center/reset, set value to centre/reset,
- PV previous_val: available only when buttons MO or fuction is list of
0 - no change
1 - instead of setting value to centre/reset when key is released,
it is set to previous value, which was active before key press
- RO rotate: available only if fuction is list of items (multi-position)
0 - no rotate
1 - rotate from max item to first item and back
steps of setting of keys (C b E 1< 1> 2< 2> 3< 3> d< d>):
- sequence:
function -> momentary -> reverse -> prev_val -> function_long -> reverse_long -> prev_val_long
- MO momentary: only available for 2-state functions (channel, ...)
0 - switch, key press will switch something (channel value, ...)
1 - momentary, value change will be active only while key is pressed
- RE reverse: only available for 2-state functions
0 - normal, no-press or default value is left endpoint
1 - reverse, no-press or default value is right endpoint
- PV prev_val: only available for 2-state functions
0 - key release or OFF state sets value to left endpoint (noREV)
1 - key release or OFF state sets value to value active before
key press or ON state
- function_long: function applied when long press of key happens,
choose from the same list as function,
identified by "V" symbol
- reverse_long: same as "reverse" + "V" symbol
- prev_val_long: same as "prev_val" + "V" symbol
Functions assignable to trims:
OFF - nothing, it is possible to assign each button individualy
as key
TR1, TR2 - trim of channel 1/2
DRS, DRF, DRB - dualrate of steering/forward/back
EXS, EXF, EXB - expo of steering/forward/back
CHn - change channel "n" value in range -100...100
STn - subtrim of channel "n"
SST - steering speed turn 1...100%
SSR - steering speed return 1...100%
CSn - channel speed for channel "n" 1...100%
4WS - 4 wheel steering mix -100...100%
DIG - DIG throttle mix -100...100%
MP1 - Multi-Position 1, switches position up/down
MP2 - Multi-Position 2, switches position up/down
MP3 - Multi-Position 3, switches position up/down
MP4 - Multi-Position 4, switches position up/down
Functions assignable to keys:
OFF - nothing
CHn - switch channel "n" value from one end value to opposite end
value. There is special handling for CH3 button. When using
3-position switch instead of CH3 button and momentary is
selected for this button, then centre 3-pos value will also
be detected and set to servo (use 1K resistor to GND to get
middle state)
CnR - reset value of channel "n" to centre
4WS - switch crab (CRB) no-crab (NOC) for 4 wheel steering
DIG - switch DIG mix between -100 and 100 (more useable when using
return to previous val key setting)
DGR - reset DIG mix to centre
MP1 - Multi-Position 1, switches position up (at END back to 1.)
MR1 - Multi-Position 1 Reset, switches position to first one
MP2 - Multi-Position 2, switches position up (at END back to 1.)
MR2 - Multi-Position 2 Reset, switches position to first one
MP3 - Multi-Position 3, switches position up (at END back to 1.)
MR3 - Multi-Position 3 Reset, switches position to first one
MP4 - Multi-Position 4, switches position up (at END back to 1.)
MR4 - Multi-Position 4 Reset, switches position to first one
T1S - start/pause timer1
T1R - stop + reset timer1
T2S - start/pause timer2
T2R - stop + reset timer2
BRK - switch on full brake, this overrides throttle position
BLS - battery low shutup, stop beeping, predefined to END-long
