fyrstormer
That's what the slipper clutch is for. No reason to compromise the diff and reduce traction in order to get drivetrain-saving slip, when there's already a component in the drivetrain intended for that exact purpose.Honestly, I'd still putty it first. My front wheels get bound first since they lead into the tight situations. Sometimes the rear never make it because I bind the front up and back it out. Quite often they get stuck between logs or something and something has to give.
I agree in principle, but based on my experience with crawling, any slip on the front axle is a hindrance, because when you're crawling, sometimes the wheels are rotating so slowly that even the thickest diff fluids (including silly putty) can still diff-out enough to make the vehicle stop moving. Regarding over-torquing the axles, that's one of the reasons I went with the MIP steel axles; the motor I'm using will never generate enough torque to damage those axles.If you aren't satisfied, takes 10 min to get the diff back out, open 'er up, and jb weld anyway. Putty isn't permanent, jb is. I would say who cares, diffs are cheap, but then you can put shafts, wheels, etc at risk too.
