I have the supershafty 6mm outputs on my transmission and the bearings have gone bad. I cant find the bearings anywhere. supershafty has the sizes listed as 10x6x4 and 16x10x5. Any help finding these would be appreciated
Super Shafty web site said:2 6mm Outputs (Left/Right)
3 2mm screws
1 11 x 6 x 4 bearing (Needed to replace the End Bell Bearing)
1 16 x 10 x 5 bearing (Needed to replace the other End Bell Bearing) - See more at: WRAITH 6mm OutPuts - Super Shafty
I think you've got the size wrong on the smaller bearing, unless the complete transmission has different bearings than those that come with the 6mm output conversion.
The 6x11x4mm are common and should be readily available.
Thanks for the help guys. I thought the size may have been listed wrong.
I don't want to be excessively picky but to avoid confusion it needs to be noted the stock Axial front output bearing is 8x16x5 NOT 10x16x5.
Only the HH or SS 6mm outputs take a 10x16x5 at the front.
You are right about the stock bearing, I wasn't paying enough attention. Mine use 8mm and always have. The old style SS uses 10mm. The newer SS versions I redesigned also take the stock 8mm. The 8mm bearing is stronger.
