1/35 4WD FORD F-150 DIY SET (New Product Preview)
This is my first time to do this kind of hobby.
They are wheel weights, I have a pair and although you cannot run the foams with them they almost act like an internal beadlock. "thumbsup"
CNC Axles for OH35P01 will be available on September!
Great news Sam - any ideas on the price?
Also, any reason why you're not using these on the 1/35 Pick Up metal chassis design?
You must have a load of stuff going on in your head... :shock:
Ordered one of these from Banggood.com on July 30th with all the electronics and a battery for my sons birthday. Still waiting. Can't wait to start putting this truck together with the kid.
MA-550 for OH35P01 (New OP parts)
MA-550 CNC axle set. Width 55mm.
MD5-350 for OH35P01 (New OP parts)
MD5-350 Drive shafts.
SA0013 for OH35P01 (New OP parts)
Metal gears.
SA0014 for OH35P01 (New OP parts)
Sa0014
Sound Unit will be available on Banggood too
Sound Unit for Micro RC Crawlers
This soundunit is developed specially for electric powered RC. It could be used to 1:35, 1/24 and 1/18 RC crawlers. Especially suitable for Orlandoo F150 OH35P01 KIT Assemble Climbing RC Car Parts Version
Features:
• Plug and Play
• Soundquality 22KHz
• Internal 1W amplifier at 8 Ohm speakers
• All connections done by plugs, no solderwork necessary
• Receiver signals are used for speed information, this allows brushless or DC Motor usage
• Fully assembeled in SMD technology (no heavy, vibration sensitive components)
• All wires included
• Very little dimensions and weight
Technical Datas:
Dimensions: 11 x 23,5 x 3,2mm (min.11x16x3,2mm)
Voltage: 3V to 5V (supplied by the receiver) Note the maximum supply voltage of 5V!
Current: app. 10mA without sound, app. 250mA at max. volume
Speaker: 8-32 Ohm
Output power: 1W at 8-Ohm at 5V; 0,6W at 8-Ohm at 3V
Proportional inputs: Positive Impuls 0,8ms bis 2,0ms
Soundquality: up to 22,05 kHz
Teaching the sound unit for throttle idle/accelerate point:
1. Power on transmitter and receiver. LED blinks fast -> normal mode. Bring throttle stick to idle. Motor must not move.
2. Bridge study switch for about 0.5 seconds until beep -> LED cont. on.
At this moment the idle position of the throttle stick is stored.
3. Move throttle stick to your desired acceleration point (throttle stick position where idle dead band stops and engine running sound starts) and wait for a beep. Now the dead (neutral) band of the speed channel is defined.
4. Move the throttle stick to full speed position and wait for three beeps. After this the sound unit is back in the normal operation mode.
