CrawlinMike
Johnny this damn Devestator still ain't showed up. I emailed and they said it stuck in customs a bit and gave me a tracking number. Literally all it shows is that it cleared Canadian customs. Odd.
Damnit.. I can't stop eyeballing the BOMBER. :shock:
Looks good. But remember you will not get truggy points with all that frame rail behind the cab
If you care about that sort of thing
nut getting too hot and not sticking to the rod? the rod needs more heat than the nut. so kinda work heat into the rod on both sides of the nut to get the rod good and hot.Need some help trying to weld nuts onto cage for mounting fenders ? Anyone done this I got one mounted well onto brake line section. The second I tried going on a solid rod part of the cage and I've failed twice now
