Johnny this damn Devestator still ain't showed up. I emailed and they said it stuck in customs a bit and gave me a tracking number. Literally all it shows is that it cleared Canadian customs. Odd.
there were a bunch of guys running wraiths with trailing arms f&r in colorado for the u4 racing, and they worked quite well.
i dig the bomber, but now that im not baller status anymore ill just be happy with the projects and rigs i got. ;)
Looks good. But remember you will not get truggy points with all that frame rail behind the cab
If you care about that sort of thing
Next build I may care. I would need help at that point from someone helping me get things perfectly square. This is pretty rough but for learning from YouTube it's not bad.
Need some help trying to weld nuts onto cage for mounting fenders ? Anyone done this I got one mounted well onto brake line section. The second I tried going on a solid rod part of the cage and I've failed twice now
Im back...
Miss me yet?
Ok ok it will come...anyway
The indy group might be going to toys for tots at the badlands this Saturday 5th 1:1 and might do some rc crawling anyone else interested in going?
nut getting too hot and not sticking to the rod? the rod needs more heat than the nut. so kinda work heat into the rod on both sides of the nut to get the rod good and hot.
also, i will sometimes prebraze the nut so all i have to do is flux the prebrazed nut and rod then just heat it hot enough to flow the brazing again.
regardless get that rod good and hot before moving the heat to the nut and the brazing joint otherwise it just wont stick and bead up on the much hotter nut.
(kinda makes me feel gross saying nut so many times)
Trucks getting closer got fenders mounted. Truck looks slightly out of proportion. Could go with or without fenders
Car stuff. Class one stuff. Mo6 beetle stuff. Ribs beer wings repeat.
Oh yea. Reef tank stuff too. But you don't know about that shit
Little stuff taking forever
Electronic mounts and side body mounts for Velcro done
