Drm31078
Yes Dlux made it in his new home where he is filling orders.:lmao:
Its the "universal sway" or "bomber sway"? Since the crawler rig has wraith rear its shorter, so i wouldn't think the bomber sway would fit?
No I didn't. I prefer to run it with the torsion bar forward. I will say that I don't think the VP bar will even fit through the rear mount because it is a bit thicker than the Dlux fab bar which is pretty snug in the rear mount. Also, the width is narrower in the rear and with the brass bushings and inserts in the Currie arms it really does fit perfect in the forward mount, like it was designed for the bomber forward mount. If I moved it to the rear I'd have to cut the bar down about half an inch and then machine 4 flats back into it. Eff all that noise. You'll see when you get yours bilinvic. There's plenty of room between the arms and the shocks through the entire travel so no problems there either.
What I've seen to make it work in rear bumper mount is to drill it out to fit vp rod, then either cut down the brass bushings or another member on here carefully drilled a bigger hole so the brass bushings would fit into the rear mount. Doesn't seem worth it.
Its the bomber sway. Universal sway has carbon fiber arms. "thumbsup"
Made some progress today on both builds. Finally got my hands on a VP sway bar and I have to say it was very much worth the wait. It went on with zero modification to the Bomber and there's no slop anywhere. Really made a difference in the amount I can twist by hand. This thing is awesome and the design is great. Screws grab the torsion bar by both sides and the arms bend out to clear the chassis with ease and allow you to run the links inboard of the arms. Good stuff VP!
What sway? Mounted where? What shocks? On my Currie sway, the links could be a bit longer, maybe 5mm or so but I definitely could not have used the supplied VP links that came with it. My rig is lowered about 1/4 inch.
