Brake line vs DOM or other tube
johncraddock445
florence ky
The last chassis, i built I did so using brake line. It worked just fine and I very may well end up using it again...I was wondering if DOM or any other tubing has a significant advantage. If so where is this best place you have found to buy/order it?
Sent from my VS980 4G using Tapatalk
I have been using brake line for years now and haven't had a problem with it. It all depends on how you build the frame and brace it.. I built one 9 years ago and I stood on it and I'm 225 pounds.. Wish I still had the picture to show... But over time time the tubing might bend in some spots. An brake line is cheaper then Dom tubing..
Sent from my 2500HD
Hydraulic line is a little more expensive than brake line but has a thicker wall. And isnt coated so its ready to weld. I can get it at the local hose shop in good lengths. And it's already straight, not the coiled stuff.
Local hose shop? Should I be looking for a metal shop or something else?
We have a place called house of hose, its a place that builds hydraulic hoses sells all sorts of different sizes shapes and styles of any kind of hose you can think of. I would think that any. It's kind of a speciality shop its not like an auto parts store that also builds hoses.
I've used 3 kinds my favorite being Stainless.
Brake line, it's soft and you have a coating to remove before you can use it safely. But, it is cheap and locally available.
DOM tubing. This stuff seemed very soft and easy to bend to me. I found it to work the best in areas of my build where tight radius bends were nessisary. It never seemed to kink.
Stainless, very strong. Easy to prep and braze, I was able to go with thinner walls to save weight without a reduction in strength. It's harder to work but I feel the end result is worth it.
Nice find!!
Just looked at it closer, its every bit of 18 ga. (.048 I believe), so I'm stoked. $1.79 a pound. I do go fast desert builds so this should be perfect. A U4 is in the future if I can figure out how to shrink the spindles up front for 2.2s to clear so I can race it in the Trophy 2.2 class.
I use mainly 1/4" x .035" 304 stainless welded tube. It is about $1/foot from onlinemetals.com. Easy to work using a handheld tubing bender, pipe cutter (one that is rated for cutting stainless), dremel, and file. Relatively light at 0.08 lb/foot. Simple frames may end up close to a pound, and more complex frames may be around 2 pounds. I considered the .028" wall, which would be good too, but I wasn't sure if it would be strong enough for a go-fast. Also, I don't see the need for seamless/DOM tubing for rc. The welded stuff from onlinemetals is just fine. You can't see the seam unless you are looking for it, and I believe tensile strength is basically the same as it's seamless/DOM counterpart.
I also use 3/16" x .028" stainless tube (seamless/DOM) and 1/8" stainless rod for smaller frames or details on a larger frame.
Online Metals and McMaster also offer decent prices on 4130 chromoly tube, though it is still very expensive. Being in the pacific northwest, I like that I don't have to worry about rust on a stainless frame, and I can even run raw tube if I want. If I were welding, I may consider the chromoly or mild steel. By the way, if anyone has a cheaper source for small diameter chromoly tube/rod (anything 1/4" or smaller), please share!
